ThinkPad X1 Nano (20UN) bricked
  • nordlicht
    • Oct 2020
    • 6
    • Switzerland
    Hi guys,
    while trying to mod my ThinkPad X1 Nano (model 20UN) I got too impatient to hold the wires pressed to the SPI Flash contacts, so I soldered wires to it, but wasn't paying attention when connecting my programmer and, stupidly, swapped VCC and GND. Thus I fried the main SPI Flash, and I only have an incomplete/corrupt dump (u49_incomplete.bin). The secondary SPI flash on the board (W25Q256JVEIQ) seems to hold two redundant copies of the EC firmware (at 0x1000 and 0xc0000) as well as a redundant BIOS copy. I am fairly confident that the secondary Flash dump is correct (dumped 3 times with the same checksum).
    I replaced the main Flash with another of the same type and tried to reconstruct the BIOS region using the image extracted from the BIOS update, however the laptop still won't turn on. The power LED flashes when I plug in the power adapter (meaning the EC firmware is loaded successfully), but when the power button is pressed, there is no visible reaction (no power LED, no fan, no keyboard backlight).
    After hooking a logic analyzer to both SPI Flashes simultaneously, I see that the platform is trying to boot, but seems to fail at some point. This is what happens when power is applied and the power button is pressed:
    • SFDP is read from the secondary Flash (u89.bin)
    • EC FW is read from the secondary Flash at 0x1000
    • SFDP is read from the primary Flash (u49_incomplete.bin)
    • Flash descriptor region is read from the primary Flash (4k at 0x0)
    • Weirdly, the Flash descriptor region is erased and reprogrammed with the exact same data (confirmed by dumping the Flash again afterwards and comparing)
    • No more accesses on either SPI Flash. After a while, if power was applied from battery, the platform turns off. If AC power is connected, the laptop stays on indefinitely.
    Having done some research on the Intel boot process, but realizing I still don't know enough about it, I am turning to the experts as a last resort before giving up and buying a replacement mainboard. From what I can see, it seems that the process doesn't fail because of Boot Guard, because it doesn't even get far enough to validate anything. Nothing is read from the primary Flash apart from the Flash descriptor region, which matches with a BIOS dump of the X1 Nano I found online, so I'm pretty sure this is not the problem.
    I would be very grateful for any help with reviving this laptop.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11901
    Re: ThinkPad X1 Nano (20UN) bricked
    X1 Nano Gen 1
    • nordlicht
      • Oct 2020
      • 6
      • Switzerland
      Thank you for the files. However, even after flashing it, the laptop still doesn't turn on... Any ideas?
      • nordlicht
        • Oct 2020
        • 6
        • Switzerland
        After replacing the diode between the 3V3 rail and the SPI Flash VCC, the power LED, fan and keyboard backlight turn on but I don't get any display output and the laptop turns off again after a while.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11901
          Do you have two 32MB bios chips ?
          • nordlicht
            • Oct 2020
            • 6
            • Switzerland
            Yes, I only replaced the primary chip and flashed it with the image you posted. The secondary chip seems to be OK - I uploaded a dump of it in my first post, u89.bin
            • hoaca388
              Badcaps
              • Jan 2022
              • 11901
              u49_incomplete
              u89 keep the original bios
              This bios is so weird
              • nordlicht
                • Oct 2020
                • 6
                • Switzerland
                Just wanted to let you know I managed to fix the laptop by taking the dump you posted first and replacing the individual ME partitions with the partitions from my secondary chip dump.
                I also reinserted the product key from the Windows registry into the BIOS NVRAM, so automatic activation should work again as well.
                Any idea which role the OA3 ID has regarding Windows activation? Is it tied to the product key?
                • o2809013
                  • Mar 2022
                  • 11
                  • Turkey
                  You replace only ME region or all security partitions? ( ACM, IBB, KEY MANIFEST )
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11901
                    Can you share the complete file of the 2 bios chips?
                    • lari_stz
                      • Dec 2012
                      • Bulgaria
                      Can you share the complete file of the 2 bios chips u49 and u 89. Thanks a lot in advance
                      • duhaash
                        • Sep 2023
                        • 4
                        I have run into a similar problem with x1 Nano. I did not do anything with the laptop and it weirdly stopped doing anything. Now, when I connect the power cord the power led blinks and then nothing. Pressing the power button does nothing. Sometimes, the power led comes on and then goes off after few seconds. I am not sure what to do.
                        I am a newbie in flashing, and I don't know where to start. Can someone help please.
                        • alfredposadas09
                          • Aug 2020
                          • 343
                          • Philippines
                          upload your original bios we help to build it
                          • duhaash
                            • Sep 2023
                            • 4
                            Thank you so much for replying.
                            I don't have my original bios. Actually, the laptop died on its own and I was not trying to update or flash it. How do I get my original bios?
                            I only have this screenshot of the bios screen with me.
                            How do I flash it to unbrick it? DO I need an eeprom programmer to do it and if yes which one would I need?
                            I am sorry for so may basic questions but I dont know where to start.
                            • duhaash
                              • Sep 2023
                              • 4
                              • alfredposadas09
                                • Aug 2020
                                • 343
                                • Philippines
                                ch341a or svod
                                • duhaash
                                  • Sep 2023
                                  • 4
                                  Thank you for your prompt response. Really appreciate it.
                                  one more question - Do I need to desolder the chip from the board or use an SOIC8 connector to program it onboard?
                                  • xchhico
                                    • May 2017
                                    • España
                                    Hello, can someone tell me the number of q263 and q261, I received the laptop without those ICs. Thank you
                                  • mmahmoud
                                    ThinkPad X1 Nano (20UN) bricked need bios
                                    by mmahmoud
                                    my laptop lenovo x1 nano is bricked after update bios, can you please help me
                                    Lenovo X1 Nano Gen 1
                                    Type: 20UN - X021US
                                    S/N: R9-116XT2​
                                    Here is the bios dump:...
                                    01-25-2025, 11:17 AM
                                    Lenovo ThinkPad X1 Nano Notebook X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X1 Nano Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Nano boardview and X1 Nano schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-07-2024, 07:12 AM
                                    09-07-2024, 06:31 AM
                                    Lenovo ThinkPad X1 Nano + 3Yr Premier Support Notebook X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X1 Nano + 3Yr Premier Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Nano + 3Yr Premier Support boardview and X1 Nano + 3Yr Premier Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-07-2024, 05:20 AM
