CF-19 Mk3 (board number DFUP1718ZA) password
  • Jan0132
    • Aug 2021
    • 8
    • Suomi
    Hi, can somebody help me with CF-19 Mk3 (board number DFUP1718ZA) password remove, thanks.
  • AAAC
    • Jan 2020
    • 459
    • Mexico
    Re: CF-19 Mk3 (board number DFUP1718ZA) password
    @Jan0132
    I was able to decode a password from your bios file, but by the characters in the password I'm in doubt if it will work or not... password is case-sensitive.
    password = G :48(6F'
    G - GOLF ( UPPERCASE )
    SPACE (press SPACE-BAR)
    : - punctuation mark (colon)
    4 - 4 ( digit )
    8 - 8 ( digit )
    ( - punctuation mark (open-parenthesis)
    6 - 6 ( digit )
    F - FOXTROT ( UPPERCASE )
    ' - punctuation mark (single quotes)
    Last edited by SMDFlea; 04-08-2022, 05:15 AM. Reason: CF-19 Mk3 (board number DFUP1718ZA) password
    • Jan0132
      • Aug 2021
      • 8
      • Suomi
      Originally posted by AAAC
      @Jan0132
      Hi, thanks , maybe i try that little later, clean bios file would be better because it is lot of work to assemble cf-19 back together to try that password.
      Last edited by SMDFlea; 04-08-2022, 05:16 AM. Reason: CF-19 Mk3 (board number DFUP1718ZA) password
      • Jan0132
        • Aug 2021
        • 8
        • Suomi
        Hi, still need bios file without password, thanks!
        • fxreen
          Banned
          • Sep 2022
          • 39
          • Brazil
          A little late for the correct password . . .
          Admin Password: 3aprily2k
          Note that the User and/or Admin password are case sensitive.
          • jasakl
            • Apr 2024
            • 6
            • germoney
            Hi, i have a lot (about 100 pcs) of CF19 Mk3 Toughbooks with Modelnumber CF-19KHR88PE. The Bios ist passwort encrypted and the hdd encryption is still active.
            Can anyone decode the passwort? I would be happy.
            The Hex should be: 7E 13 96 A6 04 3A 7E CD FE 60 30 F4 5A 87 D8 9A 33 2E 8E C1 E9 54 44 E8 9F 7B FA 0E 55 A2 B0 35 0B C9 66 5C C1 EF 1C 83 77 16 D2 A9 2D 3D 88 D0
            E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B 01
            i already tryed to clear the hex values where the password is stored, but it dont work. Maybe i did something wrong.​
            Thank you very much.
            • danito
              • Jun 2016
              • 1151
              耥耠耕耒耹耒耧
              • jasakl
                • Apr 2024
                • 6
                • germoney
                Originally posted by danito
                耥耠耕耒耹耒耧
                what do you mean?
                  • 22109
                  RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                  You MUST:
                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                  • jasakl
                    • Apr 2024
                    • 6
                    • germoney
                    Ok, sorry,
                    Machine number: CF-19KHR88PE
                    Serialnumber: 9JKSA15110
                    Boardnumber: DFUP1718ZB (1), 0PR03014, DL31u1718AAC, 2 MAIN 9J
                    Other numbers (maybe servicetag IDK):AB0123456789 9JKSA15110 T1304Y
                    I think all devices have the same passwort.
                    The Hex keys are idetical at Amitsesetupguid.
                    I share a other BIOS dump now (from a device i keep for passwort recovery), because my last dump is from a device which died recently.
                    All informations are from the same device.
                    • AAAC
                      • Jan 2020
                      • 459
                      • Mexico
                      @jasakl
                      I've checked both of your files, the password is hard-coded in the BIOS firmware, but at least the actual password could be recovered:
                      password = hancock
                      h - hotel ( lowercase )
                      a - alfa ( lowercase )
                      n - november ( lowercase )
                      c - charlie ( lowercase )
                      o - oscar ( lowercase )
                      k - kilo ( lowercase )
                      • jasakl
                        • Apr 2024
                        • 6
                        • germoney
                        @jasakl
                        password = hancock
                        Thank you very much. It works fine. now i can turn off hard drive encryption and boot from other devices.
                        You saved my week.
                        • davood2001
                          • Jun 2021
                          • Iran
                          Hello
                          i have a panasonic touhbook cf-19 mk3 model
                          the problem is my bios is dead and i need a bios dump to clean it nad flash it on a new bios chip
                          can anyone help me?
                          machine number = CF19KHRAXAM
                          serial number = 9CKSA52964
                          board number = DFUP1718ZA
                          • peste
                            • 13747
                            • ROMANIA
                            Originally posted by davood2001
                            Hello
                            can anyone help me?
                            post the contents of the bios chip even if it is corrupted..
                            • davood2001
                              • Jun 2021
                              • Iran
                              I have been trying since that day, but the bios chip is completely gone, the programmer cant even detect it, (the programmer is ok and detect other chips)
                              Is there any chance i could make it right?
                                Acer Predator PH315-51-539A Notebook Helios 300 Specification for Upgrade or Repair
                                This specification for the Acer Predator PH315-51-539A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH315-51-539A boardview and PH315-51-539A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 08:20 AM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                                Lenovo IdeaPad 330S Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad 330S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 330S boardview and 330S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 330S...
                                09-06-2024, 07:36 AM
                                Acer Aspire A515-54G-752X Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Aspire A515-54G-752X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-54G-752X boardview and A515-54G-752X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 11:14 AM
                                Acer Swift SF314-56G-79D1 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Swift SF314-56G-79D1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-56G-79D1 boardview and SF314-56G-79D1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 10:56 AM
