HP 15-ba025nv BIOS (Missing Details)
  • Acnologia
    • 429
    • Poland
    Hello!
    Tried all the tools of DMI , NBDMIFIT ,and they don't work.
    So i have the "working bios" but full errors on the serials etc. everything is missing.
    Anyone have the dump , so i can -reflash- and then re-try the DMI to fix the problem of missing serials etc ?
    Code:
    In case it's needed the details of the laptop for the repair of the BIOS Dump
    LA-D711P Motherboard code.
    Serial : CND6391LR1
    Product : Y5M13EA#AB7
    IC : 6317A-RTL8723BE
    SCT: RCPRERT13-0876
    • 22276
    Re: HP 15-ba025nv BIOS (Missing Details)
    Originally posted by AccountSaver
    Hello!
    Do you have the original bios backup, if you do, post it.
    • Acnologia
      • 429
      • Poland
      Hello!
      Code:
      Serial : CND6391LR1
      SCT: RCPRERT13-0876
      It's the above BIOS ,it's working but missing details.
      Nevermind i repaired it, found another BIOS Dump , then re-flashed, and then re-inserted the DMI information ,and it's good to go
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers šŸ˜€,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
        šŸ”§ Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        šŸ’€ Problem:šŸ˜…
        - Device shows ā€œAdministrator Passwordā€...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • greelidd
        K6604J Vivobook RTX 4070 BIOS Dump Request
        by greelidd
        Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
        Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
        09-01-2025, 06:14 PM
