Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
    Re: Macbook M1 bypass FMM / EFI Unlock
    Originally posted by killeur View Post
    Hello every one,
    i want to thank you all for effort and contribution,
    I was wondring if any one had tried to replace the ssd nand ships and reset the mac from dfu mode using Apple configurator App ? like replacing a normal ssd would that bypass FMM ? i am new so forgive me if iam saying bullshits.
    Regards.
    Hi Killeur,
    you can't with newer macs, since the hard drive is soldered onto the motherboard.
    Cheers!
      Originally posted by Mario1241 View Post
      Hi Killeur,
      Cheers!
      hello Mario,
      thank your for your reply,
      for replacing the ssd nand iam already aware that is soldered to the motherboard, and i didn't say that it will be easy to replace it even more to bypass FMM if the swap is successful.
      but i already read that it is possible with the right skills: https://www.google.com/url?sa=t&sour...q4tYb80tIOUmJ_. (link for an article about Chinese upgrading ram and ssd on m1 model)
      regards.
        hello Mario,
        regards.
        hi killeur
        If it is what I have seen in the information of all the research reading. I haven't tried it because I don't have the tool and the other one is like hitting the tower if I can't make it work again. But this sure the hard drive has to do with the whole crash. And more as it is designed. Look at this.
        https://eclecticlight.co/2021/01/18/...l-and-m1-macs/
          Hi Killeur,
          Cheers!
          No. You need to swap M1 with one clear.
            hi I have m1 macbook pro max device MDM. I deleted ssd and install new OSX MONTEREY after I said no internet connecting full installed device. I am going to recovery mode
            terminal csrutil disable. gives an error message
            csrutil: the Os environment doesnt allow changing security configuration options.
            Ensure that the system was booted into Recovery OS via the standart user action.
            I need help
              Originally posted by betonel View Post
              There is some guy on youtube showing how he open terminal inside activation window on M1/T2 mac.
              keywords: M1 terminal inside Internet recovery MacOS Monterey
              How is this possible? We need to find key combination, for the moment found way to open log window / save logs to usb.
              HI ive been doing some research back 2 years ago and i can tell you that it is possible to open terminal on activation recovery only on T2. the command is you press repeatedly command+T (terminal) right after you select language.
              ive tried this on M1 but doesnt work.
                Here are some of the pictures i took while opening terminal on activation lock screen on T2 using the command+T
                  I need help
                  SOLVED:I showed ssd as startup disk. after restart.
                  recovery mode and terminal csrutil disable
                  bingo worked .
                  after I paid check_m8 for mdm bypass software. it is working now without MDM.
                    Hi. Can't activate terminal with command+t on m1
                      Is that exploit on the old bridgeos?
                        Thank so much for sharing.
                          hello ethiogsm,
                          may i ask you how to open terminal on T2 mac on wich step you did that ? i need your assistance to reproduce it please. i tried to hold cmd+t with no success.
                          thanks in advance.
                            hello
                            I share that yesterday I started to compare the information of my mac M1 unlocked and locked.
                            I used the hidden menu on the unlocked M1 and found that the preboot drive had 3 files and the locked mac only had 2.
                            What I see is that the unlocked one has a file called active.
                            Do you think this is the one in charge of having the pc unlocked, I tried to copy it but I have no way, how do you see? what do you think?
                            Cheers!
                              hello ethiogsm,
                              thanks in advance.
                              Hi killeur
                              you just press the key command+T repeteadly in recovery screen while you are at the language selection part.
                                Hi killeur
                                hello ethiogsm
                                thanks for your return, even with internet recovery does that work ? another question does the workaround also work with Monterey?
                                  I've posted a method of accessing a Terminal in the thread about unlocking T2 based Macs.
                                    Broh this is so.... I have no idea how you spwn. I can't dm you idk why, so if you can pls do it. If not, you edit some info.p and change the iA_springboard?
                                      Has anybody tried to startup a locked M1 with a working OS installed on external drive?
                                      Maybe someone could share a image of a running MACOS installation for M1 to try it myself.
                                      Thanks in advance and thanks to everybody for sharing your knowledge.
                                        I can't dm u either it's weird
                                          Anyhow I've got all decrypted ssh logs and files of mina emc checkm8 and iremove T2 bypasses
