Help for Bios Bin and Location Of Bios Chip. LA-F841P
  • kamot37
    • Sep 2016
    • 35
    • Philippines
    I nee your help guys i need to locate the Bios IC for my laptop
    Brand: HP Pavilion Gaming Laptop
    Model: 15-cx0139tx
    Board: DPF50 LA-F841P REV:1.0
    and also if you have a working Bin Files for this..
    Note: Those Picture attach are not mine but they are semilar.. thank you in advance..
  • hoaca388
    Badcaps
    • Jan 2022
    • 11209
    • Viet Nam
    Re: Help for Bios Bin and Location Of Bios Chip
    read name of chip
    • kamot37
      • Sep 2016
      • 35
      • Philippines
      thank you for a quick reply its
      Part Number QH128AHIG
      Manufacturer XMC
      i already remove the chip and i download bios bin on support site...
      but there's error on Verification
      004: The currently selected:XM25QH128A@SOIC8-200, capacity: 128Mbits,
      16Mbytes.
      010: C:\USERS\A-I\DESKTOP\NEW FOLDER\08477.BIN
      011: File has been loaded, checksum: 16bits_0xCEFE £¬32bits_0xCB5DCEFE :
      012: Chip pins contact is detected OK.
      013: Chip ID verification OK.
      014: Start writing chip......
      015: Auto erasing...
      016: Erase successful£¬Elapsed time£º38.29 seconds¡£
      017: Start writing...
      018: Write successful£¬Elapsed time£º57.43 seconds¡£
      019: Auto verifying...
      020: Chip verification error, start position: 0x210000.
      021: Verification failure£¬Elapsed time£º2.764 seconds¡£
      022: Status register1 values: 0x0 ¡£
      023: Write error, operation terminated.
      here some bin from support i have no idea which is bin
      • hoaca388
        Badcaps
        • Jan 2022
        • 11209
        • Viet Nam
        Before, do you have backup your original bios ?
        • kamot37
          • Sep 2016
          • 35
          • Philippines
          i cant backup the old Bin, there's error on read..
          • hoaca388
            Badcaps
            • Jan 2022
            • 11209
            • Viet Nam
            Maybe write error and you will lose everything. Must backup original bios file in case of failure with new bios.
            • kamot37
              • Sep 2016
              • 35
              • Philippines
              im not sure if the old dump is good.. beside i already erase it because i cant able to backup..
              • hoaca388
                Badcaps
                • Jan 2022
                • 11209
                • Viet Nam
                It can be a wrong action, bios repair should be based on old bios , that's best, "Read" bios operation is the first operation in bios flash process and it should not be ignored.
                Do you have sevice tag number ?
                • kamot37
                  • Sep 2016
                  • 35
                  • Philippines
                  the Unit s Have power, but you cant Power On. no respond when you Press On/Off Button.
                  Sorry i forgot to mention the problem of the laptop.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11209
                    • Viet Nam
                    Re: Help for Bios Bin and Location Of Bios Chip. LA-F841P
                    Problem of your programmer.
                    • kamot37
                      • Sep 2016
                      • 35
                      • Philippines
                      my Programmer are OK just use it this morning for Acer bios Chips and its working..
                      • FLUKE289
                        • Jan 2022
                        • PHILLIPINES
                        my programmer are ok just use it this morning for acer bios chips and its working..
                        can you send your bin files tanxs....
                        • peste
                          • Dec 2016
                          • 12262
                          • ROMANIA
                          what is the problem you have ?? what do you need ??
                          • jhitcare
                            • Jun 2022
                            • India
                            this is tested ok bin
                            Model: 15-cx0139tx
                            • peste
                              • Dec 2016
                              • 12262
                              • ROMANIA
                              Model: 15-cx0139tx
                              this is the EC bios (if that's what you asked for) from the bios you posted... I couldn't find a picture...
                              • Vanciu0304
                                • Sep 2022
                                • 4
                                • France
                                hello everyone, please help with a working bios dump for my laptop:
                                HP Pavilion 15-cx0008nf,
                                DPK54 LA F841P rev 1.0,
                                SN CND83026RG,
                                PROD ID 4KG41EA#ABF
                                thanks to everyone in advance. P.S unfortunately I don't have the old dump bios
                                  by SMDFlea
                                  Bad...
                                  09-02-2021, 04:40 PM
                                • hotcrossedbuns999
                                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                  by hotcrossedbuns999
                                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                  3. I could only locate two chips that look like bios chips. Could someone verify this
                                  01-03-2025, 12:32 PM
                                • BMCappelletti
                                  Asus Chromebox CN62 - wrong chip put on BIOS reader
                                  by BMCappelletti
                                  Long story short:
                                  - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                  - gave the computer to his son a couple years later
                                  - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                  - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                  (seems like the story was not that short)
                                  He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                  01-08-2025, 07:27 PM
                                • thxd43
                                  Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                  by thxd43
                                  Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                  I have a Lenovo ideapad 330S - 14IKB laptop.
                                  The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                  02-23-2023, 08:37 PM
                                • inck243
                                  Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                  by inck243
                                  Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                  The BIOS...
                                  07-25-2024, 09:17 AM
