AMITSESetup Decryptor
  • EineWildeStehlampe
    • Jun 2021
    • 13
    As a lot of older firmware images use the well known, incredibly secure AMI XOR key to encode the supervisor password in the firmware image, I wrote a small Python tool to automate the process of searching through the image and decrypting the key. It is far from perfect but works well enough for me to share.
    The tool uses UEFIExtract to dump the entire image, naively search for a folder ending in "AMITSEDecrypt", iterate through the body.bin to find all possible hashes stored in there, decrypt them with the XOR key, remove every second byte, then convert to ASCII.
    Usage: python3 AMITSEDecrypt <Path/to/image.bin>
    Hope it'll be of use to someone and excuse my horrible Python skills.
  • crowntoy99
    • Oct 2012
    • 265
    • india
    Re: AMITSESetup Decryptor
    good jobe
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1238
      • France
      good job, untested for the moment, thanks
      • Ghamidi
        • Mar 2020
        • 303
        • France
        great job thank you
          • Jun 2021
          • 13
          I meant "AMITSESetup" obviously.
          • Ghamidi
            • Mar 2020
            • 303
            • France
            I tested work perfect
            thank you so much
              • Jun 2021
              • 13
              Glad it's of use to someone. I'd love to keep a list of devices using the AMITSESetup variable if only I could find out how to edit my posts
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1238
                • France
                see with a moderator to modify your first post.
                • LatinMcG
                  • Jun 2015
                  • 73
                  • USA/Puerto Rico
                  this works with some of the Panasonic laptops.. not all tho.
                    • Jun 2021
                    • 13
                    Confirmed to work with at least those devices, will add more when I have some in:
                    - Microsoft Surface (Pro) 3
                    - Advantech MIO-5251
                    - Medion Lifetab P8912
                    - ASUS Vivobook Flip 14 TP412
                    I've noticed there's also a few AMI implementations storing the password in cleartext instead of scancodes, I'll probably add something to parse those aswell. And then there's some that look like SHA1 hashes, so I might at least add some functionality to detect those.
                    • onizzbox
                      Banned
                      • Nov 2018
                      • 604
                      • Brazil
                      @EineWildeStehlampe
                      Similar to this here?
                      I'm finishing the script in C++ to make it faster, I'll post it in Badcaps next week.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1238
                        • France
                        Originally posted by onizzbox
                        @EineWildeStehlampe
                        nice job as usual onizzbox
                        • onizzbox
                          Banned
                          • Nov 2018
                          • 604
                          • Brazil
                          Thanks! Maxpower3
                          Would you like to anticipate the release?
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1238
                            • France
                            Thanks! Maxpower3
                            no need, I already know your work and you have already shared a lot of knowledge and tools with me
                            • onizzbox
                              Banned
                              • Nov 2018
                              • 604
                              • Brazil
                              @EineWildeStehlampe
                              @SMDFlea
                              I forgot to remove my credentials in the attached video, I can't edit the post anymore. Could you please remove it?
                              • onizzbox
                                Banned
                                • Nov 2018
                                • 604
                                • Brazil
                                Thank you Max!
                                Helping users on the forums or outside of them has always been a hobby, I don't depend on it for a living. I've always liked to share my knowledge, that's the only way we can evolve.
                                  • 21439
                                  @SMDFlea
                                  removed.
                                  • BootLoader1
                                    • Aug 2020
                                    • 70
                                    • Poland
                                    I wrote small software for decrypt AMI BIOS Password. Software can read Admin and Boot password, just open file or drag and drop a file.
                                    Enjoy.
                                    • onizzbox
                                      Banned
                                      • Nov 2018
                                      • 604
                                      • Brazil
                                      Enjoy.
                                      @BootLoader1
                                      Very cool, but it doesn't work!!
                                      Needs repairs...
                                      • BootLoader1
                                        • Aug 2020
                                        • 70
                                        • Poland
                                        Working, working, but I forgot about this case. Now fixed and working well.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
