please clear me or mod stock bios G532LWS
  • hoaca388
    Badcaps
    • Jan 2022
    • 11640
    #41
    Originally posted by Eric Ranger
    Problème admin password bios carte mere g532lws r1.3
    Pc asus rog strix g712lws
    Serie L9NRKD002689367
    Merci
    Post your dump bios.
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
      • 20665
      Merci
      This is an English language forum !
      • Marphy
        • Aug 2023
        • 3
        • CZ
        #43
        need repair BIOS - no screen issue.
        NTB Asus G712LWS-EV003T
        Motherboard G532LWS R1.3
        S/N: L6NRKD02778125A
        Original BIOS attached
        Thank You
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • hoaca388
        Badcaps
        • Jan 2022
        • 11640
        #44
        Thank You
        Wrong chip backup. The file you backup is NVIDIA firmware.
        • Marphy
          • Aug 2023
          • 3
          • CZ
          #45
          OMG, sry, wrong IC :-/ Attached (I hope) right file :-)
          Thank You and sry :-)
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • AkaBukai
            Is it okay to flash stock bios onto the motherboard's BIOS?
            by AkaBukai
            Hi there,
            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
            The little LED on the power button is flashing slowly and nothing happen.
            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
            So I decided to flash the BIOS using a cheap programmer.
            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
            I also...
            12-19-2024, 12:15 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
