840 g3
  • Genova
    • Jan 2020
    • 116
    • FRANCE
    840 g3
    Hi guys,
    i got a computer from a public auction and this one asks me for a company email address when i try to install windows 10 pro, nothing to do with a normal windows 10 install.
    So i think that this pc was linked to the company in the event of theft and that this security is integrated into the bios? can we delete it if this is the case?
    For information this computer is not stolen, i have a purchase invoice
  • lapfix
    • Mar 2020
    • 2714
    • my workshop
    Re: 840 g3
    you mean bitlocker !
    • Genova
      • Jan 2020
      • 116
      • FRANCE
      Re: 840 g3
      Do i need to replace SSD ?
      i already restore security defaut and tpm and nothing changed.
      Edit : There is no bitlocker partition on the disk
      • lapfix
        • Mar 2020
        • 2714
        • my workshop
        Re: 840 g3
        Try with diskpart command to fomat your HDD.
        https://lecrabeinfo.net/tutoriel-dis...ns-disque.html
        • Genova
          • Jan 2020
          • 116
          • FRANCE
          Re: 840 g3
          All security defaut restored, all partition erased, same thing i think HP serial number is registred by the old company or something else.
          I admit that here I am a little lost
          • lapfix
            • Mar 2020
            • 2714
            • my workshop
            Re: 840 g3
            moi aussi...maybe someone have an idea...post your old dump
            • Genova
              • Jan 2020
              • 116
              • FRANCE
              Re: 840 g3
              I found, the serial number is registred in old company with Microsoft Azure.
              This is why during a reinstallation and once connected to the internet the pc requests a connection to a company account.
              So nothing to do with the bios.
              • Jaffa015
                • Apr 2021
                • 8
                • The Netherlands
                Re: 840 g3
                This is what i would call an autopilot lock.
                They company were this unit is registered to is using Azure/autopilot to configure the device.
                It's not only bound by serialnumber but also the HardWare Hash.
                Best option for you is to do a fresh install while not connected to the internet, go through the initial setup until you see the desktop and than you can connect to internet.
                this prevents the pickup of the Azure Profile and you can use the laptop like normal.
                Im wondering if changing the system serialnumber will also prevent the pickup of the Azure profile. i Have a couple of units with this problem laying around. Does anybody have instructions how to change serial numbers in HP laptops?
                • japlytic
                  DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                  by japlytic
                  In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                  Tried (only with keyboard/mouse connected):
                  • BIOS + database update
                  • Using latest Windows 11 image built with official image creation tool
                  • Previous setup version for Windows 11 installer
                  • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                  • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                  • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                  06-19-2025, 04:59 PM
                • 24gsm
                  MacBook Pro A1708 install macos fail
                  by 24gsm
                  hi to all
                  i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                  after enter to recovery and format hdd 1to .
                  after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                  can help please
                  Serial Number: FVFXP0U0HV2J
                  Config Code: HV2J
                  Find My Mac: OFF
                  04-16-2025, 03:57 AM
                • duwane
                  A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                  by duwane
                  Hi All.
                  Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                  The issue:
                  Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                  10-26-2022, 07:02 AM
                • mnciks11
                  ACER WITH WINDOWS 11 STARTED ASKING FOR A BITLOCKER KEY RIGHT AFTER REMOVING THE RAM
                  by mnciks11
                  Hello everyone
                  I am faced with a weird problem, a client came in the office to upgrade the ram on his acer aspire 3 A315 11th Gen, the ram was upgraded perfectly fine, then after that the machine keeps looping on the bitlocker key, it can not pass that screen of bitlocker, went to bios to change secure boot policy but still the same, tried everything guys that i can think of, still doing the same thing, client does not have the microsoft account for recovery, so here i need your brains...I programmed the bios with a virgin file with no serial number still asking for the bitlocker...
                  08-27-2024, 12:57 AM
                • TrumanHW
                  MacOS: R|W Programmers like CH341x BINs..?
                  by TrumanHW
                  For years I tried figuring out how to R|W BINs from my CH341x programmer.
                  From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
                  I'd expect many here figured it out (easily), but in case not ...
                  It's one of the few forms of "how-to" remuneration I can GIVE BACK.
                  This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
                  This may be the easiest means to copy-paste:
                  Code:
                  SERIAL -to- USB - CH341 ROM (MacOS):
                  Install xcode:				xcode-select --install
                  Relocate
                  04-08-2022, 02:33 PM
