need bios dump dell latitude 5420 (cpu 11th)
  • kamkooltech
    kamkooltech
    • Jun 2019
    • 117
    • nigeria
    #881
    Originally posted by SMDFlea
    Did you save the original bios before trying others ? .If you did we can check if the service tag in the bios matches with the one you gave, and check if the configuration is ok. If you havn`t got the original bios then we can only assume that the service tag is right one, but the base cover might be from a different laptop.
    From the laptop configuration (see attached csv file) based on the service tag the CPU should be an i5-1145g7 - Tiger Lake. You can check the CPU part number to see if it is or not (somettime the motherboard model number will have the chipset name in it).
    Also from the configuration you will see it has non-vPro CSME firmware with ME disabled. There are more that 900 posts in this thread and there will be some bios with clean CSME/ME firmware matching that particular configuration.
    Use MEAnalyzer to check which bios versions have clean (Configured) firmware or not clean (Initialised) ,and look at the chipset support, if it says TGL it`s Tiger Lake, if it says CML it is Comet Lake. Obviously if you have a Tiger Lake CPU you
    don`t want to use a Comet Lake bios.
    boss you are too good take me, this is a big class you teach me
    • LBTT1121
      • Nov 2024
      • 653
      • Việt Nam
      #882
      try bios NonVpro and feedback
      • kamkooltech
        kamkooltech
        • Jun 2019
        • 117
        • nigeria
        #883
        Originally posted by peste
        post the contents of the bios chip even if it is corrupted..
        boss, i'm sorry for late replied. i did not save the bios file i met on the chip because it did not power because i have a universal working file i usually use for 5420 but i make used of it, it come up but no image show on the screen and it did not make any Alt+F sound the chip number Gigadevice 25R256DY10
        WORKING FILE I USE POSTED
        • johnnypicnic
          • Jul 2025
          • 9
          Can anyone help me with this bios? I ran the 8FC8 patcher but get 3 amber 6 white "Flash corruption detected by SBIOS" error code and then the colour test sequence.
          ST: 6Q0R5G3
          • LBTT1121
            • Nov 2024
            • 653
            • Việt Nam
            #885
            ST: 6Q0R5G3
            load bios into original IC
            • johnnypicnic
              • Jul 2025
              • 9
              Do I have any options if I don't have the original IC?
              • froilas
                • Aug 2025
                • Philippines
                #887
                Hello. Can you help me provide an unlock bios dump for Dell Latitude 5420 - GDF40 LA-K491P Rev:3.0 (A02)
                Service tag is DSD24J3
                I flashed the wrong file and I don't have my backup bios dump.
                Thank you
                • rex98
                  • Feb 2023
                  • 1287
                  • Mandaue CEBU, Philippines
                  #888
                  Thank you
                  here
                  1st boot press f2 write service tag reboot then the press alt +f
                  • froilas
                    • Aug 2025
                    • Philippines
                    #889
                    Originally posted by rex98
                    here
                    Tried this on Neoprogrammer 2.2.0.10 using W25Q256BV as IC since XM25RH256C is not available on the list. After flashing it, when turning it on. Only a faint amber light appear when holding the power button and dissaappears when released, with no video output, no post.
                    I'm using the ch341a v1.7 and wson8 probe to flash the bios (since i don't have any micro soldering skills)
                    • rex98
                      • Feb 2023
                      • 1287
                      #890
                      flash this if its tested. the first one i sent is LA-K491P same as yours and its working. this second one is also working.
                      remove the chip do not use probe and verify after flashing.
                      make sure to remove the cmos battery before flashing.
                      • froilas
                        • Aug 2025
                        • Philippines
                        #891
                        Okay. I'll bring all the files you provided to my local techinician as I don't have the proper tools and skills yet to remove a chip. Thank you so much for the assistance and have a good day.
                        • spencertech
                          • Aug 2021
                          • 23
                          • south africa
                          #892
                          help bios password, & DISABLE ABSOLUTE latitude 5420
                          service tag FB3F1J3
                          • Blaze Tech
                            Learner
                            • 212
                            • Ghana
                            #893
                            service tag FB3F1J3
                            try
                            • spencertech
                              • Aug 2021
                              • 23
                              • south africa
                              #894
                              Originally posted by Blaze Tech
                              try
                              NOT WORKING
                              • Thenicksmith
                                • Sep 2025
                                Hey I'm all new to this and I need help. I have a 5420 and It had a system password lock. Someone else took a look at it and wiped the bios clean so the chip is blank so I don't have one to upload. Does anybody have a bios I can install on this? Help is very appreciated. I did get the chip to read on my programmer and it is blank.
                                ST: JMPC2F3
                                MB P#: GDF40 LA-K491P
                                Rev: 3.0 (A02)
                                2021 - 04 - 28
                                Chip: Windbond W25Q80DV
                                  • 21439
                                  ST: JMPC2F3
                                  Rev: 3.0 (A02)
                                  2021 - 04 - 28
                                  There`s 900 posts in this thread and you`ll find a working bios in here, somewhere, just try some.
                                  The W25Q80DV chip is not the bios, it`s for something else, maybe the thunderbolt firmware. Look at the boardview/schematic and confirm if it is thunderbolt or not. If it is there will be a TBT dump on the forum or in this thread. It`s a common mistake that inexperienced members make to backup, erase or try writing to the TBT chip thinking it`s the bios chip.
                                  • Edonhiran
                                    • Jun 2025
                                    • 5
                                    #897
                                    I have dell latitude 5420 motherboard and no any details about ST or old bin file. All erased. I have tried lot of bin files from this thread but not working and different results like no display, power light blinking and etc.. Please I would like to somebody to help me, how to resolve this.
                                    Only I have motherboard number, Dell Latitude 5420, GDF40 LA-K491P REV : 2.0 (A01) 2021-04-28
                                    Thank you very much in advance and appreciate any response.
                                      • 21439
                                      There`s 900 posts in this thread and you`ll find plenty of confirmed working ones. If none work then maybe there`s some other problem.
                                      • mirjana
                                        EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                        by mirjana
                                        I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                        The embedded controller is MEC5107-LJ (UE1).
                                        The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                        I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                        If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                        Thank you in advance!...
                                        07-16-2025, 12:55 AM
                                        DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                        09-06-2024, 03:21 PM
                                        DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                        09-06-2024, 09:23 AM
                                        09-06-2024, 08:47 AM
