need bios dump dell latitude 5420 (cpu 11th)
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    #321
    Re: need bios dump dell latitude 5420 (cpu 11th)
    Originally posted by layad
    thanks would you help me with second one pls?
    Here's your Unlocked file.
    all donations are welcome,
    • layad
      • Nov 2011
      • 244
      #322
      ur star , thank you so much
      • layad
        • Nov 2011
        • 244
        #323
        have the last one, will it be too much for you to ask again?
        • hardware1
          • Sep 2021
          • 2943
          • N/A
          #324
          NO isn't, anytime you have a problem just ask about it and when I got a free time will try to help you.
          • layad
            • Nov 2011
            • 244
            #325
            this one didnt work , keyboard flashing then off , could be my backup dump is bad? i read it tow time , i have an other backup file did it with flashrom, sorry for keep asking you
            • hardware1
              • Sep 2021
              • 2943
              • N/A
              #326
              Your both files are Identical, try to put your original backup and see if the device will work or not.
              • layad
                • Nov 2011
                • 244
                #327
                yes you are right the original backup acting the same, i dont know if the chip gone bad or the dump file no good!
                • hardware1
                  • Sep 2021
                  • 2943
                  • N/A
                  #328
                  Make sure you have soldered the chip properly and didn't miss or move any component close to the bios chip.
                  • darckreign1984
                    • 260
                    #329
                    dell la-k491 rev 2 (a01)
                    pwb 2fm7c
                    laptop dead after dell update app reset pc to update bios
                    thanks again
                    • darckreign1984
                      • 260
                      #330
                      pwb 2fm7c
                      thanks again
                      processor srk03
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12069
                        #331
                        pwb 2fm7c
                        thanks again
                        Try
                        • darckreign1984
                          • 260
                          #332
                          Originally posted by hoaca388
                          Try
                          tried now laptop its dead like before
                          I use tl866II
                          i flash on chircuit (without removing chip.)
                          APP Version : 12.35 Model : TL866II Plus
                          Device : XM25QH256B @WSON8
                          Erase ...Succeeded. Time : 54.172 S
                          Data Protect Disable...OK!
                          Programming FLASH ...Succeeded. Time : 127156ms
                          Verifying FLASH ...Succeeded. Time : 97000ms
                          Programming STATUS REG ...Succeeded. Time : 0ms
                          Verifying STATUS REG ...Succeeded. Time : 94ms
                          Programming ...Succeeded
                          i dont know what to try next.
                          • darckreign1984
                            • 260
                            #333
                            whe i plug power adapter caps led turn on.
                            if i press power nothing happen.
                            after some more tries to power - keyboard led turn on - fan no spin.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12069
                              #334
                              Try this file
                              • layad
                                • Nov 2011
                                • 244
                                #335
                                i made sure no parts been removed while putting back the chip , the chip is soldered just right , i believe the chip gone bad, ordered an other chip online, thank you so much , i appreciate you help
                                • darckreign1984
                                  • 260
                                  #336
                                  Try this file
                                  i tried this file same result.
                                  laptop its dead.
                                  I did not post quiqly - i wanted a replacement chip for bios, i found one in hp elitebook, so i tried this one. Same result.
                                  caps light up when connected to power adapter. Dont react when pressed to change status
                                  fan dont rotate.
                                  • darckreign1984
                                    • 260
                                    #337
                                    its there other chip that its updated ? laptop was working, a frend of me let it to update de bios, with dell utility, i think his laptop have bitlocker (dell say that this can ruin bios update)
                                    maybe other chip that its updated loose firmware? in this update?
                                    • darckreign1984
                                      • 260
                                      #338
                                      UT7 READ its good?
                                      • layad
                                        • Nov 2011
                                        • 244
                                        #339
                                        sorry to bother you again , couldnt find 25r256jven chip on ebay , checked datasheet and found W25Q256JVEQ, based on datasheet they have the same output and input, and the same size, i have two laptops which i believe they need replacing chip , 3420 and 5420 both they have 25r256jven, i reflashed them with their backup dumps , but the laptops acting dead like no bios chip installed, with their original chips they come on but with flashing lights , colours on the screen .. etc( btw bothe of them were working before i touch them) , are they wrong chips? or do i need to do something before flashing them?
                                        • darckreign1984
                                          • 260
                                          #340
                                          Try
                                          i discover that ut3 chip its verry hot.
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
