Latitude 7380 Kylo Ren 13 CS MLK 17945-SB
  • latin_m
    • Oct 2021
    • 15
    • Ukraine
    Dell 13-7370 not boot after bios update, help please
    origin bios
  • latin_m
    • Oct 2021
    • 15
    • Ukraine
    Re: Need dell inspiron 7370 bios
    no its 7380 Kylo Ren 13 CS MLK 17945-SB 448 OFG06 00SB
    Any help ?
    • latin_m
      • Oct 2021
      • 15
      • Ukraine
      Re: Latitude 7380 Kylo Ren 13 CS MLK 17945-SB
      I`m still looking for bios to 7380 Kylo Ren 13 17945
      • tony stark
        • Aug 2017
        • 36
        • india
        try this
        • latin_m
          • Oct 2021
          • 15
          • Ukraine
          no, it does not work, there is no reaction to the power button
          I found an older dump that was made earlier, maybe it fits better,
          and I also noticed that the bootloader is shifted
          • latin_m
            • Oct 2021
            • 15
            • Ukraine
            Friends help please, I will help in my turn with beer
            • onizzbox
              Banned
              • Nov 2018
              • 604
              • Brazil
              @latin_m
              Why were you updating your BIOS? Password?
                • 22084
                The bios and everything else is free here,working and non working.No payment required,and it shouldn`t be asked for... or given
                Its strange,youve got ME version 12 firmware in both backups,yet the Latitude 7380 only supports 11.8 .Your service tag is 1234567 as well.What have you done to the bios,don`t you have the original one.
                • latin_m
                  • Oct 2021
                  • 15
                  • Ukraine
                  No, the BIOS downloaded and started updating itself, then the laptop rebooted and gave an error and now it does not respond to the power button, the owner of the laptop told me this.
                  • latin_m
                    • Oct 2021
                    • 15
                    • Ukraine
                    no, that's all there is
                      • 22084
                      Post the service tag thats on the case,also check motherboard part number again
                      • latin_m
                        • Oct 2021
                        • 15
                        • Ukraine
                        The bottom cover is all worn out and most likely not the original color differs from the main color of the case, the servistag is not visible, here is a photo of the board from the inside.
                        • onizzbox
                          Banned
                          • Nov 2018
                          • 604
                          • Brazil
                          @SMDFlea
                          Strange, new laptop with worn lid, service tag changed to "1234567", No ill-successful update would do that to the BIOS. Badly told story!!!
                          • latin_m
                            • Oct 2021
                            • 15
                            • Ukraine
                            The laptop is not new, bought on ebay, to my friends, I convey everything from his words, the bottom cover is pink, and the model on it is 7370 for this reason, I thought it was 7370, but after disassembling the laptop I realized that it was 7380
                            P.s. All people lie, and maybe this is not the whole truth about this laptop, but for me it is not so important, it is important to try to restore it
                              • 22084
                              Originally posted by onizzbox
                              @SMDFlea
                              The bios is from an Inspiron 7380 (i should have looked closer),not a latitude,no wonder the ME FW is different. The bios update at dell for the 7380 is also for the inspiron 7580. Can`t find a 7380 dump but found a 7580. Whats even stranger is that comparing both the flash descriptor is a bit different.One things for sure,the bios has been messed around with .
                              • sunbabu369
                                • Oct 2021
                                • 42
                                • india
                                post your service tag number.i will share you file
                                  • 22084
                                  did you read the whole thread,there is no service tag number,apart from 1234567
                                    • 22084
                                    try this one.. if it doen`t work i give up .
                                    • sunbabu369
                                      • Oct 2021
                                      • 42
                                      • india
                                      so sad
                                      • latin_m
                                        • Oct 2021
                                        • 15
                                        • Ukraine
                                        Оk i will try, thanks.
                                        Take a look here,
                                        maybe this will help
                                        https://www.badcaps.net/forum/showpo...7&postcount=12
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                          DELL Latitude 7380 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7380 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7380 boardview and 7380 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7380...
                                          09-06-2024, 08:01 AM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • legendkray
                                          BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                                          by legendkray
                                          I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                                          07-05-2025, 09:25 AM
