bios for acer aspire 7739 model : AIC70
  • alphatech
    • Oct 2021
    • Algérie
    hi everyone , i'm new & i need bios for acer aspire 7739 model : AIC70. want to flash it with svod .
  • alphatech
    • Oct 2021
    • Algérie
    Re: casper CHD dump
    motherboard hannstar j mv-4 94V-0 1145 rev: 2
    • regi
      • Jan 2020
      • 26
      • germany
      need bios dump acer aspire 7739g
      laptop fell off table and display broke.
      switches on and tried to attach external monitor but no picture.
      think it might be bios problem, would like to programm it with a working dump.
      Board is a AIC70 Rev 2.0
      • peste
        • 13924
        • ROMANIA
        Re: need bios dump acer aspire 7739g
        due to the blow, the motherboard may have cracked, or the video chip may have come off the motherboard, did you check the voltages ?? what checks did you do ?? post the original bios of the laptop ...
        • EbrahimSiami
          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
          by EbrahimSiami
          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
          **What I have tried so far:**
          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
          07-02-2025, 02:31 PM
        • Neggo
          BIOS BIN for Acer Aspire 3 A315-41-R8TH (Model no. N17C4)
          by Neggo
          Hi heveryone!
          I'm here to ask you guys about a problem I've been having with a laptop I just recieved. I came to the conclusion that the BIOS might be bricked.
          Initially the PC did turn on, the fan span for a second, the blue light was on, then the screen was barely noticeable while turning on and off, so after searching online on local and other forums I found some other people having the same issue and saying it was a bricked BIOS. I have no idea what caused it because I recieved this device in a non funcioning state.
          I will attach the bin file I was able to exctract
          02-05-2025, 06:33 PM
        • NecroFlex
          Acer Aspire 1 A115-32-C28P BIOS needed please
          by NecroFlex
          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
          02-11-2025, 08:51 AM
        • maralexbar
          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
          by maralexbar
          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
          If anyone knows how to force the external monitor as primary for Notebooks of those models
          11-02-2024, 09:18 AM
        • AppleLover123
          Acer Aspire A315-56-37qb mobo fried after programmed bios
          by AppleLover123
          Hello guys,
          i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
          a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
          Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
          But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
          with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
          11-09-2024, 05:42 AM
