hp elitebook X360 1030 G7 Locked BIOS Dump
  • ilias7790
    • Oct 2018
    • 36
    • Sverige
    https://*********/s/w644foujminphro/...SVOD3.bin?dl=0
    Last edited by Vesko356; 08-25-2023, 11:27 AM. Reason: External url removed. Bios attached to the post!
  • dammysholove
    • Jun 2017
    • 59
    • nigeria
    X360 1030 g7 password
    Kindly help with bios lock
      • 21040
      Re: X360 1030 g7 password
      Your backup isn`t good, and there`s extra code at the end because you backed it up as OTP ,one time programmable. Make another backup and don`t choose OTP
      • dammysholove
        • Jun 2017
        • 59
        • nigeria
        Re: hp elitebook X360 1030 G7 Locked BIOS Dump
        Can it be edit?? Ihavr read more than 10 times not able to compare correctly??
          • 21040
          Are you using a clip or have you desoldered the chip
          • dammysholove
            • Jun 2017
            • 59
            • nigeria
            Clip
              • 21040
              Clip
              Desolder it if you have a hot air station and a suitable adapter board. Your backup is corrupt, the clips can be very unreliable
              • Mazorca
                • Jan 2017
                • 463
                A fast way to compare two or more bins is to rar them and look at the CRC32 value.
                  • 21040
                  If there`s another bios chip somewhere, post that backup as well
                  • dammysholove
                    • Jun 2017
                    • 59
                    • nigeria
                    Havr desoldered it
                    • dammysholove
                      • Jun 2017
                      • 59
                      • nigeria
                      Hello
                      • Mazorca
                        • Jan 2017
                        • 463
                        Try this one now
                        • dammysholove
                          • Jun 2017
                          • 59
                          • nigeria
                          Originally posted by Mazorca
                          Try this one now
                          Thanks boss
                          But AFETR inserting information on it again still showing manufacturing program mode
                          • dammysholove
                            • Jun 2017
                            • 59
                            • nigeria
                            Fixed
                            thanks so much
                            • ismy4real
                              • Dec 2011
                              • 87
                              @Mazorca can you pls do clean me of this files
                              • schmid01
                                • 7
                                • Switzerland
                                Ahoi I try to fix my Laptop, after getting in contact wit ha little Water. Board was cleaned with Isopropanol and dryed at 40°C in the oven.
                                It boots sometimes and then restarts after a while. Mostly the CapsLock Key Blinks 5 Times by a Delay of 1 Second. Then the Fans start to spin at full Speed.
                                After Shutting down by loooong Press the Powerbutton, the Charging LED flashes 8 or 9 Times orange (while remaining white if the Powersource ist connected).
                                So, when the Boot Screen apears, I can manage to enter System Tools like HP Diagnostics. Everything seams to be ok - says the Diagnostics.
                                But when I try to Enter BIOS, I have to enter a Password. What's very strange, because I never set one!
                                Is it possible, that the Water caused this Password Problem?
                                Anyways, I try to reflash the BIOS now. So can you help/guide me?
                                1. I see the WINBOND 25Q256JVEN Chip, which is marked as JBIOS1 on the Logicboard. Is this the correct one?
                                2. I have a XGecu T48 (TL866-3G)
                                • hoaca388
                                  hoaca388 commented
                                  Editing a comment
                                  Yes. That is it but you backup chip 25Q128JVPQ you can use rc unlocker and unlock yourself.
                                • Vesko356
                                  Vesko356 commented
                                  Editing a comment
                                  Thread merged.
                                  Read the rules please, you must post under a related thread.
                                  You MUST:
                                  • Read BIOS guides, methods, resources and tools
                                  • Try the method at BIOS guides, methods, resources and tools before requesting help
                                  • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                  • Use search function in case someone already answered your request
                                  • Post under a related thread if it exists
                                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                  • Name your thread with make, full model numbers and request
                                  • Provide a BIOS/EC dump if possible
                                  • Attach files directly to your post instead of linking to external websites
                                  • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                              • schmid01
                                • 7
                                • Switzerland
                                Thanks for merging Vesko356 I Red the rules, but did not understand correctly, I'm sorry.
                                Thanks for your Reply hoaca388 but Idon't understand your Answer
                                So according to my symptoms
                                After Shutting down by loooong Press the Powerbutton, the Charging LED flashes 8 or 9 Times orange​
                                Which is the Chip to unlock?
                                • Vesko356
                                  Vesko356 commented
                                  Editing a comment
                                  In your request you mentioned you have a password prompt when trying to enter the bios, Hoaca tells you that you can use the RCUnlocker to remove it yourself from the dump.
                                  Read this thread to get the basics -> BIOS guides, methods, resources and tools
                              • schmid01
                                • 7
                                • Switzerland
                                Can you tell me, which of the three Chips is responsible for what?
                                Since I need to know, which one to desolder for the process.
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Post the serial number as per the rules please.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                  • schmid01
                                    • 7
                                    • Switzerland
                                    Thank you for your Help Vesko356 today I asked the seller, who could provide me the Password. It's complicated. So I'm guessing I have to look in another Forum, since the Damage of the water did not cause the BIOS Password, but the Laptop still doesn't work correctly. The Caps Lock blinks 5 Times and the Charging Led Flashes 10 Times.
                                    HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 08:27 AM
                                    HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 06:40 AM
                                    09-06-2024, 05:33 AM
                                    HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-06-2024, 11:32 AM
