RCUnlocker
  • CammyTier1
    replied
    Hi guys does this work for 840 g7s?
  • rtek1000
    replied
    Hello, I would like to unlock the MPM, so I can edit the data, where can I find a tutorial that works, please?
    - HP Probook 440 G5
    I found some tutorials on the internet, but I couldn't unlock it, via MS-DOS, Windows, or boot via file.
    Re-blocking the MPM seems to be much easier (using BiosConfigUtility64.exe).
    Ref.:
    https://www.alisaler.com/hp-dmi-late...sion-download/
    - NbDmiFit
    https://www.unknowncheats.me/forum/v...es-laptop.html
    - BIOS CONFIG UTILITY
    - EFI FILE Unlock​
    replied
    Originally posted by CraigR
    That worked! my god I have spent the whole day trying to figure this out. Could you tell me the process as I have more of these? And also a BIG THANK YOU!
    You`re welcome. Use the Guides to find and extract a virgin bios
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
    Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new. HxD Hex editor https://mh-nexus.de/en/hxd/
    The hard part is finding where all the DMI is. With some models all of the DMI, feature byte and windows key are in one big block, but in the 15-u499nr its in 3 different places, so that made it more of a challenge finding everything.
    The offsets for the 15-u499nr are
    6AE000 - 6AE0FF
    278000 - 27803F
    6AD000 - 6AD0FF
  • CraigR
    replied
    replied
    Is there maybe an update to RCunlocker? I just get a box that says unlocable content when I put my bios file in. I have an Hp x360 15-u499nr.
    Its an Insyde bios and not supported. Try this virgin bios + your DMI.
  • CraigR
    replied
  • crowntoy99
    replied
    Originally posted by minhdigital
    OK, Try Again !!
    thank s again cannot boot usb hdd canot modifide date password
  • minhdigital
    replied
    Originally posted by crowntoy99
    thank you soumach bro
    bad luk stil passsword 3 user
    OK, Try Again !!
  • crowntoy99
    replied
    Send to you
  • minhdigital
    replied
    HP elitebook 8470p.
    6050a2470001-mb-a04
    sn CNU403B0VP
    bios password canot remove with RCUnlocker
    sam one help me
    Product Name : HP EliteBook 8470p
    Serial Number : CNU403B0VP
    SKU : H5E20EA#A2N
    BuildID :
    FeatureByte :
    UUID : 68865417DD76E3119B42B30DCA0330576F
    MAC Address : A0-1D-48-F7-79-B4
    Send to you
  • crowntoy99
    replied
    HP elitebook 8470p.
    6050a2470001-mb-a04
    sn CNU403B0VP
    sam one help me
    SKU : H5E20EA#A2N
    BuildID :
    FeatureByte :
  • sereupin80
    replied
    HP Zbook Fury 17 G7
    i have tried to update the bios with the HP software, here the info i hope are useful
    TITLE: HP BIOS and System Firmware (S92)
    VERSION: 01.16.00
    DESCRIPTION:
    This package creates files that contain an image of the System BIOS (ROM) for the supported computer models with an S92 family ROM.
    PURPOSE: Routine
    SoftPaq NUMBER: sp152207
    EFFECTIVE DATE: 03/10/2024
    CATEGORY: BIOS - System Firmware
    SSM SUPPORTED: Yes
    DEVICES SUPPORTED: N/A
    PREREQUISITES: None
  • bilal1992
    replied
    god bless you sir
  • djenka
    replied
    Originally posted by Pavel Opletal
    Nope got black screen with fan at full speed. I guess the only solution will be to grab some working bios from here and transfer the original serial into it right?
    Just wait...
  • hoaca388
    replied
  • Pavel Opletal
    replied
    Originally posted by hoaca388
    Your file has corrupted ME part, RC unlocker does not work with this model. Try.
  • hoaca388
    replied
    Hello guys, RCUnlocker doesn't work for me also unfortunately (even tho it says unlock finished). Could you please help me with unlocking this bios file?
    Probook 650 G1
    Serial: 5CG4503JS9
    SKU: D9S32AV
    Bios chip: MX25L12873F
    Thanks for any help.
  • Pavel Opletal
    replied
    Probook 650 G1
    Serial: 5CG4503JS9
    SKU: D9S32AV
  • ti notebook
    replied
    Thank you so much
  • peste
    replied
    Originally posted by ti notebook
    RCUnlocker
    hp 240n g8 16MB no work
    thank you
    post the original bios, if you have two bios chips post them both..
    HP Clean VSS2 dumps,fix Endpoint Security error
    by SMDFlea
    Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
    the infamous **"Endpoint Security" error message.
    Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
    I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
    The offsets and file sizes are part of the naming convention i`ve used for the extracted
    files.
    hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
    filling everything after...
    08-08-2024, 03:14 PM
    HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-07-2024, 07:12 AM
    09-07-2024, 06:40 AM
    HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
    This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
    09-07-2024, 05:50 AM
