RCUnlocker
  • McAaron
    • Nov 2023
    • Zambia
    #921
    Re: RCUnlocker
    Kindly help me to unlock Hp EliteBook 8470p, it has BIOS administrator password.
    If there's a solution, I request you to give step by step instructions on how to do it.
    • peste
      • 12365
      • ROMANIA
      #922
      Re: RCUnlocker
      see post #1
      • FantasticallyFurstraited
        • Nov 2023
        • usa
        #923
        Re: RCUnlocker
        Hello Sirs, late to game here. Id like to use the tool but it absolutely refuses to run on any machine I have. win 10 or 11. I downloaded the file, unzipped, tried to run it it opens to: "Missing file destination argument!" Please tell me what I'm missing or doing wrong here. thanks in advance.
          • 20455
          Re: RCUnlocker
          Usage: Drag and drop .bin file to .exe file.
          • idumsat
            • Nov 2023
            Re: RCUnlocker
            Can someone please help me here? I am a newbie in this and do not know how to find bin file. Can the instructions be more clear? Step by step?
            • hoaca388
              Badcaps
              • Jan 2022
              • 11402
              • Viet Nam
              #926
              Re: RCUnlocker
              https://www.badcaps.net/forum/showthread.php?t=103526
              • TyNiX
                • Nov 2023
                • England
                #927
                Re: RCUnlocker
                Hello.
                I have a Zbook 15 G2 and for the life in me started asking me for a bios password which has never been set in the first place and I tried removing the bios battery but it keeps retaining the password. Can you guys help me out and let me know if you need any info from me and of course please tell me how to extract it
                Thank you !
                • Catmouse
                  • Nov 2023
                  • 5
                  • Luxembourg
                  #928
                  Re: RCUnlocker
                  Is there any chance this might for an HP Elite X2 1012 G2?
                  Thanks!
                  • RethoricalCheese
                    • Mar 2013
                    • 1517
                    • Estonia
                    #929
                    Re: RCUnlocker
                    Yes, it does.
                    • goldengsm123
                      • Mar 2022
                      #930
                      Re: RCUnlocker
                      Perfect tool.Work flawlessly!
                      • Catmouse
                        • Nov 2023
                        • 5
                        • Luxembourg
                        #931
                        Re: RCUnlocker
                        Originally posted by RethoricalCheese
                        Yes, it does.
                        Thank you!
                        So I still need to manage to get a dump of the bios to use it and put that .bin file into the same folder as the .exe file of your unlocker?
                        Trying to find out what I need to buy without having to remove the chip from the mainboard as I've seen people managed to do it without removing the chip.
                        Thanks!
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          #932
                          Re: RCUnlocker
                          That model has wson8 chip so you would either need a hot air station or solder very thin wires directly between chip and programmer.
                          In case of soic8, it's pretty much always possible to do without it using a soic8 clip.
                          • Catmouse
                            • Nov 2023
                            • 5
                            • Luxembourg
                            #933
                            Re: RCUnlocker
                            So there's basically no way without removing it?
                            • RethoricalCheese
                              • Mar 2013
                              • 1517
                              • Estonia
                              #934
                              Re: RCUnlocker
                              By soldering wires, it might work
                              • fixit007
                                • Sep 2023
                                • 8
                                Re: RCUnlocker
                                Unlocked 8470p, all good! Great tool!
                                Replaced CMOS battery while at at - why does HP wrap it into plastic ... Slightly shorted a good 2032 Duracell while attaching wires.
                                The program gives an error at the end, but that does not seem to impact anything, and the unlocked bios is produced OK.
                                • Schrauber2023
                                  • Nov 2023
                                  • Deutschland
                                  #936
                                  Re: RCUnlocker
                                  Thanks for sharing the RCUnlocker
                                  • fixit007
                                    • Sep 2023
                                    • 8
                                    Re: RCUnlocker
                                    Btw, I highly recommend the very simple wire-less SOIC clips that go for $2 on eBay from China.
                                    One can simply attached wires to the clip, and the other ends to Raspberry Pi. I had 20cm wires. To create some room for wires to be attached, I bent clip's pins into the middle and out in a staggered way.
                                    I saw some pictures out there where the clip wires go to a break out board first, and then have to get connected to Raspberry. That's an extra step, and tons of possible confusion.
                                    See pictures.
                                    • psyjamm
                                      • Oct 2021
                                      • 16
                                      • USA TX
                                      #938
                                      Come on guys! What wrong with you? It's simply to find on youtube how to use this utility! Put your bios dump to folder with rcunlocker.exe and than just drag your bin file to the program shortcut
                                      • Palimpu
                                        • Nov 2023
                                        hello guys.
                                        i have some problems with
                                        model: 640 G8 with 32MB ROM
                                        i have tried to overwrite the specified sectors. after each boot it resets the chip to the original value.... Is there another version of RCUnlocker for 32MB or how can I find the right sectors?
                                        thanks for your help!
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1517
                                          • Estonia
                                          #940
                                          You need to modify EC bios, not main bios. Address 37000.
                                          • Palimpu
                                            Palimpu commented
                                            Editing a comment
                                            Thank you for your feedback.
                                            I have made the changes starting from address 37000. However, it appears that it is somehow being written back from a RAM. Presumably, this is because I did not disconnect the CMOS battery. I left it installed because I'm concerned it might erase the TPM.
                                          HP Clean VSS2 dumps,fix Endpoint Security error
                                          by SMDFlea
                                          Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                          the infamous **"Endpoint Security" error message.
                                          Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                          I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                          The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                          files.
                                          hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                          filling everything after...
                                          08-08-2024, 03:14 PM
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
