RCUnlocker
    Re: RCUnlocker
    Hi, I am a newb at this, when I run the tool I get a message stating missing file destination argument, i put the files in my root C:
    Am I missing something, also how do I get the .bin file if the bios is locked?
    sorry again a newb.
    thanks in advanced.
      Re: RCUnlocker
      sorry again a newb.
      thanks in advanced.
      Just Drag And Drop. That's It
        Re: RCUnlocker
        Originally posted by evgenymgv View Post
        The situation is this: the laptop was working, the BIOS update was automatically downloaded. An error occurred during the update process. Laptop stopped turning on. A dump was downloaded from the forum, the ME region was cleared and flashed with a programmer. The laptop turned on, but there was a warning about a problem with the security device. Attached is the downloaded file.
        P.S. SPI chip 16Mb was erased before the dump was written
        The issue was resolved as follows: the update was downloaded from the official HP website, the BIOS region was cut out and inserted with a replacement into my dump. The ME region was cleared. SPI 16mb is erased, "glued" BIOS file is written in SPI 32mb. DMI data entered manually. Everything works without errors.
        P.S "Clean" firmware HP 850 G5 (without DMI, clear ME) is attached, maybe someone will need it.
          Re: RCUnlocker
          I have an HP Elite Book 840g7. i need my BIOS unlocked? Im so frazzled. What do i do how do you use that unlock tool .bin. Im confusedon how to make tool work??
            Re: RCUnlocker
            read post#1...if you don't succeed, post the original bios of the laptop..don't forget to make copies of the bios before writing..
              Re: RCUnlocker
              Hello, I downloaded the tool, and it says unlocked.
              But there are no files created inside the directory, maybe I am dumb?
                Re: RCUnlocker
                Sorry I forgot to add the files.
                There is a password, but I know it. I just guess something went corrupt.
                  Re: RCUnlocker
                  try
                    Re: RCUnlocker
                    Hello
                    HP EliteBook 850 G7
                    I wrote 16MB unlocked but caps lock blinks 7 times and won't boot.
                    32MB could not be unlocked.
                    help me.thank you
                      Re: RCUnlocker
                      Originally posted by TKTKYYYY View Post
                      Hello
                      HP EliteBook 850 G7
                      help me.thank you
                      try..
                        Re: RCUnlocker
                        thank you
                        try
                          Re: RCUnlocker
                          Hi guys! Before I buy the prong tool for my chip I need to know if this tool would work on a probook G0. If any more specs are needed to determine if it would work, I would be happy to share.
                          Thanks to everyone in advance and great thanks to RethoricalCheese for making this possible.
                            Re: RCUnlocker
                            to understand that you have a bios password and want to delete it??
                              Re: RCUnlocker
                              Can anyone help unlock the password from this EC dump on hp probook 450 g8 ?. As tried the tool and it wont work with it. Have tried both spi flash ic and ec flash ic and neither work.
                                Re: RCUnlocker
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Re: RCUnlocker
                                  Originally posted by Vesko356 View Post
                                  Many thanks for that !
                                    Re: RCUnlocker
                                    Hi! Can somebody unlock this bios for HP Elitebook 830 G8? I couldn't find 16mb chip on board. RCUnlocker doesn't support 32mb. I tried unlock bios by editing RCUnlocker to bypass 32 mb, but result it is not fully correct.
                                      Re: RCUnlocker
                                      Originally posted by WillingMagic View Post
                                      ...but result it is not fully correct.
                                      Not at all.
                                      "Dirtyhack"...
                                      Program this chip only, leave the other as is (unhacked )
                                        Re: RCUnlocker
                                        hi. Can you help me with bios password on hp 850 g8?
                                          Re: RCUnlocker
                                          Program this chip only, leave the other (main) as is. At first boot reset bios to factory default, then security settings, apply/save and restart.
