RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #41
    Re: RCUnlocker
    Both are possible but I'd modify 16MB only.
    • LenBios
      • 122
      • Ker
      #42
      Re: RCUnlocker
      ok thank you, i will try tomorrow.
      How about Elitebook 850 G7?
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        #43
        Re: RCUnlocker
        Again, both are possible but I support 16MB only right now. But back up 32MB aswell, just in case.
        • maxitaxi
          • Jul 2021
          • 11
          • nedtherlands
          #44
          Re: RCUnlocker
          Originally posted by maxitaxi
          Hi , i tried the TEST_2 file but result is the same. I can press F10 and get message 'entering setup menu'. After 10 minutes i press F1 and i get 'enterin system information' so laptops seems alive but stays in the last-message-screen.
          Retoricalcheese, here is the 32mb file
          • RethoricalCheese
            • Mar 2013
            • 1517
            • Estonia
            #45
            Re: RCUnlocker
            I will get back to you tomorrow
            • azanwaqas771
              • Feb 2019
              • 48
              • Pakistan
              #46
              Re: RCUnlocker
              not download bro can you share on here RCunlocker tool
              show this error
              • donskogvito
                • Sep 2021
                • 15
                • Norway
                #47
                Re: RCUnlocker
                I can confirm that the zip file download is working as of today.
                • smiley60
                  • Jul 2021
                  • 43
                  • UAE
                  #48
                  Re: RCUnlocker
                  hi bro
                  i unlock 840 g6 but faced with hp endpoint security problem and it s come every time that i power on the laptop
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    Re: RCUnlocker
                    Originally posted by smiley60
                    hi bro
                    Enter the bios and reset security settings to default:
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • donskogvito
                      • Sep 2021
                      • 15
                      • Norway
                      #50
                      Re: RCUnlocker
                      What are the purpose of the 1 NEW.zip attachment?
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #51
                        Re: RCUnlocker
                        I obviously answer smiley60 since I'm quoting him in my post, and it's obviously is an answer to smiley60's problem.
                        It doesn't concern you in any way. There's no need to spam the topic!
                        • smiley60
                          • Jul 2021
                          • 43
                          • UAE
                          #52
                          Re: RCUnlocker
                          thanks vesko but the problem not solved
                          but when i disable hp sure start the message gone
                          I think its must be some thing else
                          and i unlocked another hp 840 g5 and faced this problem again
                          I noticed this happen when the chip manufacture is issi
                          no problem with winbond or mxc
                          • virginlulu
                            • Feb 2019
                            • 21
                            • China
                            #53
                            Re: RCUnlocker
                            thanks!!!
                            • Korreia
                              • Sep 2021
                              • 14
                              Re: RCUnlocker
                              Hello RethoricalCheese,
                              I just want to confirm that I understand the process of Unlocking the BIOS AKA Clear BIOS Admin Password using your tool.
                              1 - I first need to read/exctract the current BIOS Config (BIN file) with the CH341a programmer with a SOIC8 SOP8 Test clip.
                              2 - Drop the extracted BIN file onto your RCUnlocker. It will do it magic and create a new BIN file.
                              3 - Using the CH341a programmer with a SOIC8 SOP8 Test clip, write back the new BIN onto the BIOS. The Admin password should be remove.
                              Is this the right step overall?
                              I have a HP EliteBook 820 G3 that I forgot the Admin password...
                              Cheers and thanks for your help!
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                #55
                                Re: RCUnlocker
                                Exactly. But step 4 would be to reset security settings in bios.
                                • jsinfo
                                  • Oct 2018
                                  • 10
                                  • Indonesia
                                  #56
                                  Re: RCUnlocker
                                  When drag the bin file to the exe file, I got this error message.
                                  The application was unable to start correctly (0x00007b).
                                  Did I make any mistake?
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1517
                                    • Estonia
                                    #57
                                    Re: RCUnlocker
                                    Not sure. Upload your file, somebody can unlock it then.
                                    • jsinfo
                                      • Oct 2018
                                      • 10
                                      • Indonesia
                                      #58
                                      Re: RCUnlocker
                                      Actually what I wonder is that I cannot run the rcunlocker.exe, however
                                      I can run hpunlocker.exe that you wrote. I tried with the locked bin file sent
                                      by other.
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1517
                                        • Estonia
                                        #59
                                        Re: RCUnlocker
                                        They use completely different code so doesn't help much. Do you have all of the files in folder like they came from the rar or did you copy it somewhere else without other files included?
                                        • tedypm2000
                                          • Sep 2021
                                          • 7
                                          #60
                                          Re: RCUnlocker
                                          Hello there.
                                          I have a HP Elitebook x360 1030 G3 that has its BIOS password protected.
                                          If I understand correctly, the only way to attempt to unlock it is to dump the bios to a file and use your tool, and the only way to dump is physically with an adaptor clip to the BIOS chip inside my laptop. Correct? Or are there ways to dump the bios without physical / adaptor use.
                                          Appreciate your time
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
