RCUnlocker
    Re: RCUnlocker
    Is there a way to dump the bios using software?
      Re: RCUnlocker
      No, sorry.
      Become a Badcaps supporter
      Thanks to all supporters.​
        Re: RCUnlocker
        Originally posted by SMDFlea View Post
        Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
        Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
        https://www.aliexpress.com/item/1005003313016522.html
        So that probe linked here is used in a similar fashion as the clip I already purchased? If so I will get it.
        6x8mm or 5x6mm?
        Its okay to still use the clip on the MXIC chip?
        *Nevermind, I ordered both sizes
          Re: RCUnlocker
          6x8mm or 5x6mm?
          According to the datasheet must be 8x6-mm.
          W25Q256JV is offered in an 8-pad WSON 8x6-mm (package code E), a 16-pin SOIC 300-mil (package
          code F) and two 24-ball 8x6-mm TFBGA (package code B & C) packages as shown in Figure 1a-c
          respectively. Package diagrams and dimensions are illustrated at the end of this datasheet.
          Looking at the photos of the ad, I have some doubts about the efficiency and the ease of use of these probes, but we will find out anyway when you get them. I hope they'll work well.
            Re: RCUnlocker
            Thank you Vesko
              Re: RCUnlocker
              Thank you Vesko
              You're welcome.
              It's hard to answer - I forgot to take the crystal ball with me today.
              However, if you show pictures of both, I could try
                Re: RCUnlocker
                You're welcome.
                Here is a pic
                  Re: RCUnlocker
                  Here is a pic
                  It's the same WSON 8 type spi chip as the other one, so you will be able to use the probes you ordered for both.
                  The clamps are used for the other type of spi chip which is called SOP8 or SOIC-8:
                  Here is a picture of the two types side by side for comparison:
                    Re: RCUnlocker
                    The one on the right is definitely like my windbond chip.
                      Re: RCUnlocker
                      Would it be possible to run it on Linux? After extracting the archive, it appears to be based on Python and I assume would be trivial to port.
                      We believe in the right to repair.
                        Re: RCUnlocker
                        anyone could help on this asus chromebox lock. Tried the program wont' unlock it. I have 5 of this with enrollment lock, any one could share the process of unlock. SN changed, still not working.
                        also attached unlocked bin won't work using the program.
                          Re: RCUnlocker
                          read post # 1 from this thread ..
                            Re: RCUnlocker
                            You have already posted your request in the Desktop PC bios requests forum - https://www.badcaps.net/forum/showthread.php?p=1143579
                            This part of the forum is for laptop bios requests ONLY.
                              Re: RCUnlocker
                              Sorry, didn't see the chromebox is supported. Thought they are the same.
                                Re: RCUnlocker
                                RCUnlocker. not working. why? ( my laptop setup. window 10 64 bit)
                                show sms: Error 0xc00007b “Application was unable to start correctly”
                                every one help me!
                                thanks
                                all donations are welcome,
                                >>>>> click on this link to donate via PayPal. <<<<<
                                  Re: RCUnlocker
                                  Usage: Drag and drop .bin file to .exe file.
                                    Re: RCUnlocker
                                    yes, but tool not working >> show sms: Error 0xc00007b “Application was unable to start correctly”
                                    can you help me unlock!
                                    thanks!
                                      Re: RCUnlocker
                                      thanks!
                                      You have already posted your bios in another thread.....
                                      https://www.badcaps.net/forum/showthread.php?t=103652
                                      You MUST NOT:
                                        Re: RCUnlocker
                                        thanks!
                                        Search google for the error message "0xc00007b" ,theres a number of reasons why,such as youre tring to run the app on a 32bit OS, the .NET framework is corrupt or not latest version, and more results
                                          Re: RCUnlocker
                                          now it work, thanks!
                                          the software is compatible with HP Elitebook 840 G6. bios chip 32M. ?
