RCUnlocker
  • Veddel%
    • Jan 2022
    Re: RCUnlocker
    Hello.I try to unlock some Notebooks with MiniProgrammer,CH341A and RC unlocker Tool.
    I am not professional in this case and need some help. What i have to do step by step.It will be great if some body can give me detailed instruction.
    Thanks a lot
    Regards Detlef
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #402
      Re: RCUnlocker
      Thanks a lot
      Regards Detlef
      https://www.badcaps.net/forum/showthread.php?t=103526
      Become a Badcaps supporter
      Thanks to all supporters.
      • amjfrankenstein
        • Jul 2020
        • 10
        Re: RCUnlocker
        Is there anyway to port this to Linux shell I dont use windows on the rpi and it gets tedious using windows
        • hpboy
          • Jan 2021
          • 53
          Re: RCUnlocker
          Thanks a lot
          Regards Detlef
          Watch the video I posted in an earlier post - https://www.youtube.com/watch?v=QnlvlKuPMVk
          • Raiderman
            • Jun 2022
            • 18
            • U.S.A.
            #405
            Re: RCUnlocker
            Hi guys, I have a Hp Probook x360 435 G7. I found a 32mb MXIC chip, and an Unknown size windbond 25W256JVEN chip when removing the cover. Do I have a 16mb chip on the under side of the motherboard? I am not going to be de soldering. I will be using the clip on programmer, so just asking if I need to remove the MB? Neither one of the chips Ive mentioned show up in the search in the software.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11357
              • Viet Nam
              #406
              Re: RCUnlocker
              If so your bios and ec are both 32MB type, no 16MB chip.
              • Raiderman
                • Jun 2022
                • 18
                • U.S.A.
                #407
                Re: RCUnlocker
                So the unlocker will not work for me then?
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #408
                  Re: RCUnlocker
                  Obviously yes, just upload the files here, someone of us will do the job for you.
                  • Raiderman
                    • Jun 2022
                    • 18
                    • U.S.A.
                    #409
                    Re: RCUnlocker
                    You guys rock! I will do my best to get the files, but since they do not match any chip number, I will use the closest matching
                    • Raiderman
                      • Jun 2022
                      • 18
                      • U.S.A.
                      #410
                      Re: RCUnlocker
                      Here are my two files. Couldnt verify, as my chips arent in the list.
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #411
                        Re: RCUnlocker
                        Yes, you can:
                        https://www.badcaps.net/forum/showpo...8&postcount=52
                        • Raiderman
                          • Jun 2022
                          • 18
                          • U.S.A.
                          #412
                          Re: RCUnlocker
                          ok
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #413
                            Re: RCUnlocker
                            ok
                            Both are bad - ch341a?
                            • Raiderman
                              • Jun 2022
                              • 18
                              • U.S.A.
                              #414
                              Re: RCUnlocker
                              yes, and yes. on pass 8 trying to verify windbond
                              • Raiderman
                                • Jun 2022
                                • 18
                                • U.S.A.
                                #415
                                Re: RCUnlocker
                                Will not verify. Every pass verification goes to 25%.
                                  • 20419
                                  Re: RCUnlocker
                                  Its because the software is shit,and also i think its because the bios chips are WSON8, the clip will not fit onto them.If they are WSON8 then you will have to desolder or solder wires from the adapter board to the gold pads connected to each chip pin
                                  Use these software alternatives,you`ll find them all posted on the forum
                                  NeoProgrammer, Colibri, AsProgrammer
                                  • Raiderman
                                    • Jun 2022
                                    • 18
                                    • U.S.A.
                                    #417
                                    Re: RCUnlocker
                                    I was wondering if the software is crap. Here is a pic of the chip. The clips seem to make good contact.
                                      • 20419
                                      Re: RCUnlocker
                                      Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
                                      Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
                                      https://www.aliexpress.com/item/1005003313016522.html
                                      • Raiderman
                                        • Jun 2022
                                        • 18
                                        • U.S.A.
                                        #419
                                        Re: RCUnlocker
                                        Ya, I may just bag the whole thing. I cant solder for sh1t. I bought the laptop second hand knowing it had a admin bios password. I am able to do a clean install of windows by pressing the f9 key at post to bring up which drive to boot from.
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #420
                                          Re: RCUnlocker
                                          My advice is to leave it as it is. You do not have enough experience and especially quality tools to do the job properly. It is possible to worsen the situation at this stage.
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
