Patching bios dumps and sercuity i2c remove computrace E531 / E530
  • neverexisted
    • Nov 2012
    • 76
    Hello, I am trying to remove computrace from about 10 laptops I got in a school auction. I'm not familiar with this setup. From what I understand the actual lock resides in the I2C chip labeled U8 on this and many other Thinkpads. I buy these allot so some better understanding would be awesome. Attached are my two Bios dumps and the third P24s08 chip which is new to me. Thanks.
    • 22025
    Re: Patching bios dumps and sercuity i2c remove computrace E531 / E530
    For models with the P24s08 or equivalent chip ,you can short 2 pins together while booting. The lenovo autopatcher will not work.
    https://www.badcaps.net/forum/showpo...07&postcount=9
    • neverexisted
      • Nov 2012
      • 76
      I have tried but computrace remains greyed out and enabled. Also on another model I can't even get autopatcher to work it just errors out.
      By that I mean I was able to do that method with success and set and clear a password but it had no effect on computrace.
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        Put a blank 24c08 (or erase the existing one from adress 0x300 if you want to keep serial machine type, etc.) and rewrite serial, etc. with lenovo maintenance disk. I did that to a T430 and worked.
        • Stunt
          Lenovo Thinkbook 16 G8 Computrace
          by Stunt
          Hi guys i've got Lenovo Thinkbook 16 G8 with computrace enabled only. Please note there is no bios password set on the laptop.
          The problem is computrace which's enabled and grayed out. Please if anyone who can help me i will appreciate it. Thank you
          Device: Laptop
          Brand: Lenovo
          Model: ThinkBook 16 G8
          Board number: 233068-5
          SN: PW0JCMEY
          Request: Remove computrace
          10-16-2025, 02:25 AM
        • kaput
          Lenovo Thinkcentre M720q, disable activated Computrace
          by kaput
          Not a BIOS request per se, but closely related. Please bear with me
          A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
          Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
          06-28-2024, 09:36 AM
        • rex98
          JS47A/JS57A/JS77A NM-E531 onboard ram disable
          by rex98
          hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
          nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
          maybe you could help me how to shift these resistors to disable its onboard ram.
          this is is the presents and not presents...
          10-07-2025, 03:39 AM
          HP Clean VSS2 dumps,fix Endpoint Security error
          by SMDFlea
          Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
          the infamous **"Endpoint Security" error message.
          Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
          I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
          The offsets and file sizes are part of the naming convention i`ve used for the extracted
          files.
          hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
          filling everything after...
          08-08-2024, 03:14 PM
        • BabyShark
          Dell Latitude E5450 Computrace
          by BabyShark
          Heya,
          I have a Dell Latitude E5450 with Computrace, service tag HTL4W32.
          Can anyone please help me with a Computrace-free BIOS, or at least point me in the right direction?
          Best Regards,
          07-21-2024, 11:29 AM
