Dell Latitude 7480 BIOS DUMP NEED!!!
  • hoaca388
    Badcaps
    • Jan 2022
    • 12419
    Originally posted by waqarali
    Dell Latitude 7480
    ST; 3X8X8H2
    MB; CAZ20 LA-E131P Rev; 2.0(A01)
    Problem No Display
    Latitude 7480
    Service Tag: 3X8X8H2
    • shlomicthailand
      • Jul 2024
      • Israel
      Hi , sorry i'm not short as the others, yesterday i updated the BIOS on Latitude 7480 since Dell said it was critical.
      the laptop is now not being able to load at all - No Display
      The ctrl+esc + AC does power for few seconds and then it shut down
      i believe there is BIOS issue here - and wanted to know
      1. if i can reflash it without soldering, for example with ch341 programmer clip ?
      2. to get the correct bin file for flashing.
      3. why everyone send Service tag - is that important? (my ST: 8DQ46H2)
      • hoaca388
        Badcaps
        • Jan 2022
        • 12419
        1. Maybe.
        2.Post your bios file here and we will help you.
        3.That's the forum's rules and it makes it easier for us to find the bios.
        Click image for larger version  Name:	2024-07-06 17_06_05-Bộ Mô Đun Lập Trình BIOS USB CH341A 24 25 Series EEPROM + Kẹp SOIC8 SOP8 EEPROM .png Views:	0 Size:	1.17 MB ID:	3303674
        • shlomicthailand
          • Jul 2024
          • Israel
          Originally posted by hoaca388
          1. Maybe.
          thanks hoaca388
          which file do you want me to upload - i don't have the programmer yet , so i can't read whats inside the chip
          need to order it :-)
          • keedier
            • Jul 2012
            • 16
            • pakistan
            hi there, i have a defective dell latitude 7480 with no display maybe its a bios problem , worth the shot i guess
            TAG = 72FF0N2
            board CAZ20 LA-E131P
            board rev is 2.0 (A01)
            thank you.​
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              #26
              TAG = 72FF0N2
              thank you.​
              looks like this bin is very corrupted or you had encorrect chip, please double check
              • hoaca388
                Badcaps
                • Jan 2022
                • 12419
                #27
                TAG = 72FF0N2
                thank you.​
                What name of chip do your read ?
                • keedier
                  • Jul 2012
                  • 16
                  • pakistan
                  #28
                  im using EZP2010 and the chip is detected as W25P80 for the both bios chip.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12419
                    #29
                    W25P80 is not a bios chip. It only has one MB of data.
                    • keedier
                      • Jul 2012
                      • 16
                      • pakistan
                      #30
                      sorry, im still new to this but i managed to find the correct bios chip on UC5 / UC6
                      TAG = 72FF0N2
                      thank you. very much,.​
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        #31
                        TAG = 72FF0N2
                        please try this your bin looks very damage, so I rebuild and get the dmi and clean the ME region please test this
                        • keedier
                          • Jul 2012
                          • 16
                          • pakistan
                          #32
                          hi, thanks for taking your time to reply. i used your bios file and my laptop still wont boot up. its weird tho because..
                          1. the charger indicator lights up to white when i connect to charger
                          2. when i connect the charger, the keyboard lights go up for 15 seconds or so then it shuts down with no display and i cant press the power button again.
                          3. when i press CTRL - ESC while putting the charger, the keyboard lights stay on for at least 15 seconds and then it restarts again and again.
                          is this a bios problem? i changed to a working RAM and a working charger already so i dont think thats the problem.
                          NOTE: i used EZP2010 for programming the bios
                          • kalilinux25
                            • Mar 2018
                            • 2093
                            • ZAMBOANGA SIBUGAY
                            #33
                            I think this is a bios issue because your backup bin is not ok, when I compare from.a working bin
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              #34
                              plese try this its from a working board bin just added dmi and clean me region
                              • gizaha
                                by gizaha
                                02-13-2024, 07:18 AM
                                DELL Latitude 7480 Notebook 7000 Specification for Upgrade or Repair
                                This specification for the DELL Latitude 7480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7480 boardview and 7480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7480...
                                09-06-2024, 08:01 AM
