ThinkPad t460s Patched Bios Request
    Re: ThinkPad t460s Patched Bios Request! 20FA
    thank you I received the file (outimage) I programmed it on the T460s I have a black screen the keyboard turns on and off the POWER button remains on but nothing on the screen, I tried to disconnect and reconnect it does not change anything.
      t460s i need patched file for my device
      hi t460s i need patched file for my device.
      I tried the patch file in the forum but it does 2x 5 beeps and closes and there is no image.
      My original encrypted dump is here.
      model : 20F9
        Re: t460s i need patched file for my device
        model : 20F9
        BIOS guides, methods, resources and tools
        Password removal by laptop brand
        Become a Badcaps supporter
        Thanks to all supporters.​
          help me my friend i need patch t460s this my old dumps
            ok
              model : 20F9
              ok
                Hello, could you help me clean the ME region?
                My laptop does NOT have the common motherboard which is REV 3.0 or 4.0.
                This is REV 0.3 and in the ME Analyzer in the Chipset section it shows me SPT/KBP-LP B
                TYPE: 20F9-Z17DUS
                S/N: PC-04F278
                Thank you
                  TYPE: 20F9-Z17DUS
                  S/N: PC-04F278
                  Thank you
                  Help me pls
                    Help me pls
                    Your problem is that no CSE Me was found in the database.
                    Version 11.0.0.1151 Corporate LP dose not exist.
                      There's no need to be exactly this version, use any available 11.0.X.XXXX Corporate LP version. Only major and minor version must be the same, hotfix and build number can be different - it's not a problem.
                      Example: AA.B.C.DDDD
                      AA - major version
                      B - minor version
                      C - hotfix
                      DDDD - build number
                      Edit:
                      Intel CSME (Converged Security Management Engine) Repository download link.
                        Help me pls
                        Yes, if you mean Vesko356 it's not a problem, I was just surprised that I
                        couldn't find the version.
                        He can try if he wants.
                        Maybe it will help him.
                          Hello Max.
                          Tried downloading the file but winRar says it's corrupt(
                          I am trying to find BIOS for Lenovo T460s BT460 U60 motherboard and Winbond W25Q128 chip. Tried a bunch of versions but no luck so far but no luck. Can you please have a look st this one?
                          Thanks!
                            Originally posted by max841982 View Post
                            Hello Max.
                            Thanks!
                            Read the rules before posting:
                              Thinkpad T460s
                              Type 20FA-S03E06
                              S/N PC0L6ZCM
                              Would someone please be able to look at this BIOS? The machine works fine but takes 15 seconds to POST and the MEI Version is blank in BIOS. Intel ME will not install. I had used lenovo auto-patcher to remove supervisor password. That worked and I have since updated the BIOS to the latest version. Thanks in advance.
                                I tried to delete password on my Lenovo T460s machine.
                                Everything was OK (STEP 1 to STEP 7) until I restore original BIOS.
                                Laptop did not power on, just 5 beeps and 5 beeps again.
                                Tried to flash the patched BIOS back - laptop power on, but not possible to boot / open BIOS.
                                Flashed back original file and 5 beeps again..
                                Should anyone please check what I did wrong?
                                Both bios included.
                                Thank you very much.
                                  Thread merged. Please read the updated rules,you must post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
                                    I'm sorry, I will do it next time.
                                    Anyway, I tried three different BIOS dump from searching here and the thirt one power on my laptop.
                                    So the problem is solved.
