Asus mb X550CC Rev 2.0, bios Dump needed
  • 3DIL
    3D!L
    • Jun 2021
    • 42
    • BRASIL
    Hi boys, need this bios dump and best regards
  • peste
    • Dec 2016
    • 12822
    • ROMANIA
    Re: Asus mb X550CC Rev 2.0, bios Dump needed
    post the backup of the bios and clear pictures of the white or green stickers on the motherboard
    • 3DIL
      3D!L
      • Jun 2021
      • 42
      • BRASIL
      here backup and sticks
      • peste
        • Dec 2016
        • 12822
        • ROMANIA
        try..
        • 3DIL
          3D!L
          • Jun 2021
          • 42
          • BRASIL
          Thank you very much peste, I did the programming but it did not work, they turn on the power + wifi led, not to mention that before it did not turn on any led, the fan turns on after 30 seconds of turning on
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Try
            Become a Badcaps supporter
            Thanks to all supporters.​
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
              BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • vinaypundith
              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
              by vinaypundith
              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
              So, I'm looking for a BIOS dump for this machine - a 16MB one....
              08-03-2024, 12:32 PM
