Originally posted by aldopc
View Post
I REQUEST BIOS FROM Dell Latitude 3400
Re: I REQUEST BIOS FROM Dell Latitude 3400
Originally posted by marc_ytos View PostGreetings, please help me remove the password from this bios, thank you very much
Greetings, please help me remove the password from this bios, thank you very muchAttached Files
Originally posted by newdes View PostHi, can you help me clean up the ME region of my Dell Inspiron 3400? If it turns on but does not give video. Thank you.
18750-1 R4GHW$LA
Next time try to give exact infos for your requests.
https://www.badcaps.net/forum/showthread.php?t=103570Attached Files
18750-1 R4GHW$LA
Can I use this bios file for my dell latitude 3500. Bolt-L UMA MB 17938-1 FW8G6$JA
Originally posted by ramrk View PostMB :Bolt-l UMA MB 17938-1 FW8G6$CA
hanging issue, any other bios programmed after going no power on condition.
can fixed it??
thank you.Attached Files
can fixed it??
thank you.
Originally posted by Vesko356 View Post"original normal alloy"
Unbelievable...OK, make yourself a normal alloy.
I don't care either. Anymore.
Fix it yourself, you can do it more properly. Obviously.
Originally posted by robsonrj01 View Postfriend with this bios doesn't care
when i put the original normal alloy
Originally posted by robsonrj01 View Postdon't call with this bios friend
model Dell latitude 3400 17938-1 FW8G6$kA
Do you think I didn't check exactly which is the model before I started doing anything?
Does the Service Tag below tells you anything? You're even still under warranty.
The file I uploaded - which model do you think it's intended for?
Here are some screenshots to look at before answering my questions:
model Dell latitude 3400 17938-1 FW8G6$kALast edited by robsonrj01; 08-24-2021, 04:21 PM.
Originally posted by robsonrj01 View Post...Originally posted by SMDFleaPost once and be patient waiting for a reply.Multiple posts and threads will be deleted.
good afternoon can someone remove the password from the bios thank youAttached Files
Originally posted by peste View Posttry..
It didn't work either, the machine consumes 0.09 on the asymmetric power supply. When we press the power it runs the cooler, turns off and stays 0.09.
Bios still didn't work, before recording the machine is locked in the Dell logo or when I pressed F12 it appeared preparing the boot menu and it was also locked.
