This device has a firmware password, not a firmware pin code. I have tried to find "$SYS" on this firmware, and nothing shows up. Removing ram (or changing it whatsoever) causes the computer to beep at boot endlessly. I have changed the drive as well, and there is still a firmware password. I have ran out of ideas, please help me remove the firmware password.
Apple MacBook Unibody Mid 2010 A1342 (820-2877-B)
Re: Apple MacBook Unibody Mid 2010 A1342 (820-2877-B)
Okay so I have found out the solution! The issue I had was that the ram sticks I first used were dead or incompatible with this Unibody/Polycarbonate MacBook, which is why those did not work. Second issue was that a single RAM stick (original stick) in the bottom RAM slot did not work. It wouldn't post. I had to put one RAM Stick on the top slot for it to boot. That let me reset the PRAM and Boot! I know the other RAM stick wasn't dead as the machine boots with both inserted. Really odd behavior. -
can someone help me with this bin has password
apple MacBook unibody mid 2010 A1342Attached FilesComment
https://www.badcaps.net/forum/troubl...23#post1622423
3.2.1. 2011 and older
For 2011 and older machines, changing RAM configuration and performing 3x PRAM reset can clear the password. Password can also be extracted from BIOS dump.Comment
by a_p3rsonHi there,
I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
This daughterboard uses an interesting...-
04-21-2025, 11:41 PM -
Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
Channel: Schematics and Boardviews
10-22-2024, 02:37 AM -
Apple MacBook A1342 K87 820-2877 Schematic...
10-05-2024, 03:02 PM -
Apple MacBook A1342 K84 820-2567 Schematic...
10-05-2024, 03:01 PM -
- Loading...
