da0zrvmb6d0 rev d working main and ec
by DynaxSCHi,
I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
...05-04-2025, 12:08 PM -
by AndreasbestHello.
Received a T480s with broken main Type C, i replaced it but it's not working (replaced it 3 times just to make sure everything is soldered correctly).
Thunderbolt charging works and laptop power up fine.
I need help to repair JUSBC port please.
Thank you!
Schematics: https://www.badcaps.net/forum/troubl...b471#post7297010-21-2024, 12:05 PM -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by MMH3Hello,
i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
Never ever i experienced problems with that.
Now i have one 5050sff machine, where this jumper isnt working at all.
I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
The history of the machine is that i used it in my office... -
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... - Loading...
