I ask for help.
Unsuccessfully officially updated the bios.
Lenovo-V14-ADA
SN: PF2ME3HR
MTM: 82C6006DRU
I really hope that I trimmed the file correctly.
Your file is identical to the official virgin bios, so it should works fine.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
is this for lenovo v14-ada? can i use eprom programmer to flash?
if you have the name and model of the laptop as in this thread ... see post #23 ... don't forget before writing the bios chip, to make a copy of the original bios of the laptop..
If anyone has a working W25Q64FW_1.8V bin for Lenovo IdeaPad 3 15ADA05. Please share. Attached is the existing one I read.
Write your Serial Number.
Thanks, but didn't work (no post, no logo, novo button doesn't work).
It's a Virgin Bios it should works fine, maybe you have something else (Hardware Issue).
Subject: Bricked Lenovo IdeaPad 15ADA05 after BIOS update - SN PF2NSx4y
I need help with my bricked Lenovo IdeaPad 15ADA05 (SN: PF2NSx4y). I've tried turning it off and on, disconnecting the CMOS battery, and all the other standard fixes for 5 hours now and nothing is working.
I need a solution to this problem, otherwise this laptop is just a paperweight. Can someone help me out here?
post the original bios of the laptop..
Did you try pressing in the NOVO button ? .If that hasn`t worked besides the other standard fixes then your only option is to program the bios. If you don`t think its something you can do yourself take it to a repair shop
Blinking Power Button on Lenovo IdeaPad 3 15ADA05 GS450/GS550&GS750 NM-C821 Rev 1.0
Completely lost here. Have this Lenovo GS450/GS550&GS750 NM-C821 Rev 1.0, which turns on sometimes and works ok, and I can go to bios, although the power button is flashing.
Other times it will just won't pull any current above 0.01A from the PSU, ON LED is lit up and the power button flashing.
I have tried to flash this bios via SPI https://www.badcaps.net/forum/showth...ighlight=GS550 it fired up and informed that needs to reser nVRAM and wont keep TPM settings and just hanged there. After restart no picture as with the original bios.
I have Reverted the original bios and loaded up at first when I resoldered the BIOS (i went to BIOS and reset to defaults), then on reboot won't turn on or will pull 0.6A but won't show any picture or keyboard response.
I am attaching the DUMP in case you find issues with it.
I must add, no liquid damage or corrosion on the board or foul play.
