Dell Latitude 5400 Bios password
    Re: Dell Latitude 5400 Bios password
    Originally posted by MBAS111 View Post
    is Serial OK: HGFB533
    Your backup fault.
    Become a Badcaps supporter
    Thanks to all supporters.
      Can i not find an original Bios?
        You said your bios has a password which means bios file in your bios chip is fine, but the file you posted back is corrupt, so the problem is your programmer, which model programmer do you use?
          neo programmer. you may be right before i looked deeper into re programming chips i made a mistake and took a bois backup from a clip. I now solder directly onto the board to reprogram. so i don't have a valid bios back up does that mean this unit is scrapped
            can an original bios work?
              Not sure.If your bios reading has failed, who can guarantee that the bios writing is successful? solve your bios reading problem or you will make things more difficult.
                problem is i have already overwitten before so that was the only backup i had
                  Does your device include one or two bios chips?
                    just the one
                      So without a bios backup is it not possible to restore the chip info back to factory?
                        Try
                        Hi, I am hoping someone can help me to disable Absolute in this bios backup.
                        I managed to permanently activate it due to the confusing wording in the bios GUI.
                        LA-G891P Tag HQ107Y2
                          Hi all.
                          Need password removal please.
                            Originally posted by procyone View Post
                            Hi all.
                            Here's your Unlocked file, try it and let me know.
                            all donations are welcome,
                              Only keyboard backlight and fan on full spin
                                Did you solder the chip Correctly? try to use your backup and see what will happen.
                                  hello bros. i have dell Latitude 5400 windows Mobile Device Management any solution this is my device bios dump thank you
                                    Problem solved thank you any ways
                                      Hi all.I don't know which chip contains the password, so I post the content from both.
                                        try
