Need bios dell latitude 3410 please
    anybody?
      I have the same problem with a Dell Latitude 3410, it does not register the service tag, can you help me?
      Service Tag: G1CKC63
      I don't have the original bios
        Originally posted by SMDFlea View Post
        Compare a locked and unlocked bios with a hex editor, its not as difficult as you might think.
        ill try this . If I can also do it
          what is the motherboard? is it MOCKINGBIRD-L CML UMA 6L 19746-1 ?
            Exactly this one
              Exactly this one
              Laptop has two chip and flash this two bins
                thank you, which tool should I use to flash this bin files? I tried with a bootable stick and from the bios update device option and it doesn't work.
                  Oh dont flash any bin I though you have take the board out and use a spi bios programmer,
                    no, i don't have a programmer
                      can it be solved without a programmer?
                        Impossible.
                        You can refer to model CH341A (this is the cheapest model). Learn how to use it via Youtube.
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          Dell latitude 3410 .With Original Bios No Power.. i Already Tried Other Bins Than it Can't Save The Service Tag.
                          Rebuild Please
                          BN 19746-1
                          ST: 2TNY103
                            Rebuild Please
                            BN 19746-1
                            ST: 2TNY103
                            use my post number161 flash both. https://www.badcaps.net/forum/troubl...92#post3252592
                              Originally posted by rex98 View Post
                              Thanks Sir .. It worked Perfectly..
                                Finally it worked.
                                Earilier I already flashed each and every dumps via SVOD3 but it didn't work. Even this dump. And today I flashed with RT809F, it worked. Don't know logic behind this, maybe SOVD3 error in my case.
                                  i try meany bios but laptop stuck on dell logo DELL 3410 ST:JH6N563
                                    Need bios dell latitude 3410 19746-1 ST: 5VBKB63
                                      I need to clean my password guys
                                      ST: J19G203
                                      EX: 41435196195
                                        ST: J19G203
                                        EX: 41435196195
                                        1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode
                                          consultation forum, I have 3 dell 3410, At first several days ago I programmed to remove the absolute. and it didn't turn on anymore explain the problem (it's like a little flash when the energy, 2 very short white LED flashes and it doesn't do anything or heat up) 2 recover the previous bios (the same) 3 I left the device stored for a few days (and suddenly when I connected it) it worked 4 load another released bios (failure) and it stayed flashing) 5 I react after weeks saved .... Now I did the same with another 3510 (i7 program directly disconnected battery and battery) and it worked Try again with another i5 10ma. and I have the same blinking error change the chips from i7 to i5 but it's the same any suggestion
