need working bin file of Asus GL504 MB REV 4.2 bios
  • balobi
    • Jan 2015
    • 88
    • phillippines
    hello! someone help me cleanme or build new bin files? problem is restart and no display.
    orig bin file attached.
    thank you!
  • sysaputra
    • Feb 2021
    • 10
    • Indonesia
    Re: need working bin file of Asus GL504 MB REV 4.2 bios
    Try this
    • balobi
      • Jan 2015
      • 88
      • phillippines
      Originally posted by sysaputra
      Try this
      still same problem. no display and keep on restarting. thank you!
      • peste
        • 12933
        • ROMANIA
        Try this
        try..
        • Mazorca
          • Jan 2017
          • 463
          Try this one and report back. OOPS, I didn't refresh window and didn't know peste had posted.
          • junkjack
            • Jul 2021
            • 6
            • united state America
            Hi i'm new to this Flashing BIOS.. done many search got me here.. my laptop GL504GW.. BIOS flashing halfway power cut.. now start laptop blank screen.. trying to flash bios chip(winbond 25Q80EW) on laptop using (CH341A USB Programmer EEPROM BIOS Flasher Programmable Logic Circuits with SOP8 Flash Clip Suitable for 24/25 Series )
            can i just flash this(shared/attached) bios in to my laptop?
            if i got password in my previous BIOS will this still work?
            i still remember/know my password
              • 21140
              Post your corrupt bios backup for fixing as it will hopefully still have your DMI info,windows key,serial .
              • junkjack
                • Jul 2021
                • 6
                Thanks for your respond.. i'm waiting for my hardware(CH341A USB Programmer...) to be delivered, is there a guide to fix this i want to try learn to fix, while waiting for the delivery
                  • 21140
                  If youve ordered the Black PCB version it might have 5V on the data lines,there`s a 3.3V mod you can do,it will
                  make the programmer a bit more stable, there`s a link to a mod in this thread
                  https://www.badcaps.net/forum/showpo...50&postcount=5 .Also in that post there`s some recommended
                  alternative CH341A software.
                  Here`s a good CH341A programming guide https://winraid.level1techs.com/t/gu...rammer/32948/3 Click on the +Spoiler to see the pictures.
                  Make 2 backups and compare them with a hex editors File-Compare function or some other method such as making a checksum and seeing if they match.
                  If you want to have a go at repairing the bios yourself here`s 2 guides,they don`t cover copying the DMI though so if you post your backup (along with a picture of the white/green sticker on the motherboard,with the barcode on it) someone will fix it for you
                  https://www.badcaps.net/forum/showthread.php?t=96604
                  https://www.badcaps.net/forum/showthread.php?t=60659
                  • junkjack
                    • Jul 2021
                    • 6
                    Just want to check again the GL504GW laptop BIOS chip location on the motherboard, its near to the RAM module? this chip "WINBOND 25W80EWNIG 1834"?
                      • 21140
                      No not that one. It will say 25Q128 as part of the name
                      • junkjack
                        • Jul 2021
                        • 6
                        where it's located? do i need to take out the heatsink? currently i just open the back cover of the laptop.. do i need to takout the entire mainboard?
                        • junkjack
                          • Jul 2021
                          • 6
                          ok i took apart/out entire mainboard.. look at front & back.. still cannot find the BIOS chip name 25Q128
                          • junkjack
                            • Jul 2021
                            • 6
                            thank you!
                            Hi need your help, could u show me where is the GL504GW BIOS chip location on mainboard? i've been trying to find the chip location, thanks
                            • Sebastian Codrean
                              BIOS file for ASUS F542UN laptop
                              by Sebastian Codrean
                              Hello to all of you! I need help with a BIOS file.
                              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                              02-20-2025, 10:25 AM
                            • caglarec2268
                              Asus X515EA Bios File Please
                              by caglarec2268
                              merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                              Now "please follow the steps below to recover your bios" text remains on the screen
                              I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                              laptop model x515ea-bq945w
                              s/n: R4N0CV02K527148
                              CN:HWFB
                              Board model; ASUS X415EA R7.0
                              bios chip: GD25Q128...
                              11-27-2024, 03:51 AM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
                            • Divendra
                              NOR Modifier to change Mac address on a good working Bios file
                              by Divendra
                              Please some one out there how to use NOR Modifier to change Mac address on a good working Bios file from the old corrupt bios file on PS5 ?. Clear under standing how to.
                              05-24-2025, 11:07 AM
                            • wakethesleep1111
                              Bios File Needed for asus tuf15
                              by wakethesleep1111
                              Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                              05-27-2025, 10:56 PM
