Dead HP Folio - Dual BIOS QFN programming question
  • MrFlaps
    • Dec 2020
    • 3
    Assumed BIOS corruption occured on EliteBook 1020 Folio G1.
    Manufacturer : Hewlett-Packard
    Motherboard : HSTNN-I28C 6050A2646201-MB-A03
    Product Name: HP EliteBook Folio 1020 G1
    Version : A3008DD18B03
    Model / Serial Number : CNU5069DVF
    SKU Number : K0H23ES#UUZ
    Family : 103C_5336AN G=N L=BUS B=HP S=ELI!
    BIOS Version : M77 Ver. 01.26
    System Board ID : 2271
    System Board CT : PFAZA001X8B07N
    Pressing POWER button results in only the LED in the F12 key lighting and the keyboard LEDs come on and fade to black. LCD is black.
    I reflashed the BIOS before the board failed. Before it was giving many errors.
    I see now there are two options : (1) buy and replace BIOS chips and (2) buy Flash programmer and flash myself.
    I now see that there are two BIOS chips, both of these are in QFN packages (image attached)
    BIOS Chip #1 is Winbond 25q16dv
    BIOS Chip #2 is Macronix mx25l12873fzni
    I would assume the tool to use would be a SOIC8 with POGO pi adaptor.
    My questions
    (1) Do I flash both chips with the same BIOS image?
    (2) Are there any other chips that require modification?
    (3) Is buying the chips likely to be more successful?
    (4) What other actions need to be performed?
    I have all the system information apart from the "Feature Byte" and build id
    This was not a password protected, something went wrong with the BIOS and it degraded from that point.
  • Loli Popu
    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 03:28 AM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • tranquility
    Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
    by tranquility
    hallo,
    i have an asus X515KA-EJ058W here.
    just both leds white...he battery blinking without battery connected
    consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
    if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
    power on again is possible but again 400mA then and no picture.
    now the really strange
    i flashed bios (some version i found on the internet) and resoldered....sometimes...
    12-11-2024, 06:47 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
