MS-N0141 VER 2.1 bios
  • kadi144
    • Aug 2015
    • 690
    • algerie
    hello alles
    i need a MS-N0141 VER 2.1 dump
    MSI MINI LAPTOP
    THANKS
    • 21444
    Re: MS-N0141 VER 2.1 bios
    https://www.badcaps.net/forum/showthread.php?t=44560
    • kadi144
      • Aug 2015
      • 690
      • algerie
      Ddr 3 no ddr 2
        • 21444
        Does the "MSI MINI LAPTOP" have a full model number ?
        https://www.msi.com/Laptop/support/U135DX ? .Isn`t the full bios available at the support site ?
        • kadi144
          • Aug 2015
          • 690
          • algerie
          thanks mr SMDFlea
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers šŸ˜€,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
            šŸ”§ Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            šŸ’€ Problem:šŸ˜…
            - Device shows ā€œAdministrator Passwordā€...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • greelidd
            K6604J Vivobook RTX 4070 BIOS Dump Request
            by greelidd
            Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
            Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
            09-01-2025, 06:14 PM
