Asus x556uj black screen
  • zikobiko
    • Mar 2021
    • 18
    • Tunisie
    Hi to all i have an asus x556uj rev 2.0 motherboard it was working fine until someday started to take so mush time to boot than sometimes it gets stuck at asus logo until one day the screen lights up (the backlight) and nothing at all it boots once in a 100 time but mostly stuck at asus logo or only back light working i left it like that for about 3 months when i opened it this time nothing happens the boot light blinks but the screen is black not even the backlight working now i decied to dump the bios i took a backup than another one but they were diffrent i took a third one and it was different from the others i think the bios chip is changing the dump every time I verify i get main memory with the contents are in disagreement it s like getting corrupted than i decided to erase the the bios chip and write blank and verify it was ok i flashed the bios with a dump i found on this forum and verify all good the error is gone but the laptop still behaving the same (black screen) i checked voltage using a repair guide i found online all voltage seems to be ok exept for VCCGT =0v
    • 22312
    Re: Asus x556uj black screen
    "main memory with the contents are in disagreement" . Are you by any chance using a CH341A ?
    • zikobiko
      • Mar 2021
      • 18
      • Tunisie
      Yes i am but the problem is solved after using auto in the program now the verify works fine but i used a bios thati found on this forum now vcccore is 0 volt too
        • 22312
        Did you make a backup first before trying the other bios ? ,if you did then post your bios backup ,also post pictures of the white/green labels on the motherboard, they are usually on or near the RAM slot .
        • zikobiko
          • Mar 2021
          • 18
          • Tunisie
          yes i did take 3 backups but they are diffrent i think because the bios chip is getting corrupted everytime i take a dump.
          after writing the new bios and verify all good the probleme is gone and this are all my dumps
            • 22312
            Try this bios, and use this alternative CH341A software .
            https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
            https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
            • zikobiko
              • Mar 2021
              • 18
              • Tunisie
              thank you for your help
              still black screen and still VCCGT =0V
              is VCCGT normal to be 0 V ?
              • zikobiko
                • Mar 2021
                • 18
                • Tunisie
                my freind i forgot that i disabled on board ram because i suspecyed it at first ow afterenabling it again it boots i am gonne stop now because i have other work to do and i ll report other issues if pesent later thank you very mush for the bios
                • zikobiko
                  • Mar 2021
                  • 18
                  • Tunisie
                  hi after flashing your bios the laptop booted fine multiple times but after 4th or 5th boot it booted to the bios menu and nothing is showing exept time editing and next boot just a black screen i took another dump and it looks very different from the one i flashed can you please take a look is the bios chip damaged? and can i replace it with a 64mb wibond mine is mx25l6473e
                  • zikobiko
                    • Mar 2021
                    • 18
                    • Tunisie
                    after comparing between my first dump and your edited dump and the new dump i find that damaged parts from the new dump is identical to the first dump very mush it s like the chip getting corrupted in the same way it was please correct me if i am wrong
                    • zikobiko
                      • Mar 2021
                      • 18
                      • Tunisie
                      hi i flashed the dump you gave me so many times but i always have boot problems after a while .i installed widows 10 now and whenever i want to reboot i have to remove the battery and hold power button and boot time is about 30 seconds and sometimes stuck on asus logo . this is my last dump after installing windows i used meanalyser and it has configuration issues and i noticed that my original dump me version is different from the one you gave me. can someone please help i am stuk here for one weak now
                      • Mazorca
                        • Jan 2017
                        • 463
                        Try this one and report back. I couldn't open yours with FIT, used UEFI tool to build image, used clean ME from repositories and Bios region from update.
                        • zikobiko
                          • Mar 2021
                          • 18
                          • Tunisie
                          Black screen my freind if you can edit my first dump i uploaded it when i opened the thread
                          • Mazorca
                            • Jan 2017
                            • 463
                            I can't do it, other than cleaning the ME region, I cannot do any repair, I do not have the skills or knowledge or tools. The first three dumps are all different, they shouldn't be, and you really shouldn't have erased until at least two or three dumps are the same. Better yet, if you suspect the chip, get another one, it might be dying on you every time it's read or heated up. Good luck.
                            • zikobiko
                              • Mar 2021
                              • 18
                              • Tunisie
                              It s because of the chip before erasing i tried with the same chip model and all dumps are the same i replaced the chip but the bios still not configured correctly i hope someone with skill and knowledge can repair it for me
                                • 22312
                                Nothing wrong with the bios i posted then if its been ok 4 or 5 reboots. The problem is somewhere else.
                                • Mazorca
                                  • Jan 2017
                                  • 463
                                  Thanks SMDFlea for clearing this up, my procedure ok? Copying DMI, using ME region from repositories and bios region from website update, building with UEFITool?
                                    • 22312
                                    Flash the bios from post #6 again,at first boot restore bios defaults. Shut down. Make a bootable memtest86+ flash drive,set the bios to boot from USB and boot from it.Run the tests.If the RAM tests ok leave it enabled,otherwise disable it again and remove the RAM chips.
                                      • 22312
                                      The part number on the white sticker is the bios that shipped with the board, x556uj ,so thats the bios region that should be used from the x556uj bios update. Cleaning the ME firmware should be done with FIT, as the firmware can have custom settings set.When you use FIT it will save the current settings from the bios you are working on,such as boot guard etc,and use those to rebuild the new bios. Some of the latest asus laptops have bootguard 5 enabled,if you copy a stock ME FW in using a hex editor/UEFITool youll lose that bootguard setting,and have a laptop that doesn`t boot.
                                      • Mazorca
                                        • Jan 2017
                                        • 463
                                        Thank you for those wise words, I could not do the build with FIT, so I used UEFITool.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Technodoc
                                          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                          by Technodoc
                                          Asus laptop G614JZ-N3012W Rog Strix with i7
                                          Mainboard G634J-PMV-VGT
                                          6050A3441302-MB-A01
                                          2023-02-10
                                          Power button works okay....power light goes on
                                          Red "bottom" leds go on
                                          Charging led works
                                          Fans do not spin, capslock key does nothing, screen stays black
                                          I would like to program the bios again, to rule out a corrupted bios.
                                          However I run into a size error
                                          The bios chip is a Winbond 25R256JVEN
                                          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                          02-24-2025, 04:46 AM
                                        • andrestecno
                                          ASUS X201e - The screen does not turn on and remains black
                                          by andrestecno
                                          I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
                                          If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
                                          Thanks in advance!
                                          07-18-2024, 07:14 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
