Acer nitro fh51s la-k181p rev; 1.0
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    HELLO sir,,, can you help us to have a good working bios file for
    this
    ACER NITRO FH51S LA-K181P REV; 1.0
  • peste
    • Dec 2016
    • 12811
    • ROMANIA
    Re: Acer nitro fh51s la-k181p rev; 1.0
    this
    post the backup of the bios
    • Marc97
      • Jan 2016
      • 189
      • Phillipines
      my box cant recognize the IC xmc,, via EZP 2019,, AND VIA ch341a,, my plan incase i get good file is to write on other IC which known by my common box,,
      but i still find a way to read the ic for back-up to post
      i only read the other ic winbond,, just 1mb
      the other ic name label was XMC possible it is 16mb
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        hello sir,,, anyone,,, thank you if you hel us,,, to find need file above
        • Marc97
          • Jan 2016
          • 189
          • Phillipines
          Can you help us,,
          • hilar
            • Nov 2014
            • 42
            • turkey
            test ok
            • sito
              • Apr 2016
              • 22
              • indonesia
              any have main bios ?
              this my backup but no display
              • adiasterix81
                • Aug 2017
                • 36
                • Romania
                Originally posted by marc97
                my box cant recognize the ic xmc,, via ezp 2019,, and via ch341a,, my plan incase i get good file is to write on other ic which known by my common box,,
                the other ic name label was xmc possible it is 16mb
                this is uv49 chip and is for video bios. I tested myself this atachement and it works. Big thanks
                • soul299
                  • Aug 2023
                  • 38
                  • Philippines
                  Can someone have a working bios with 16mb bios bin?
                  original bios i lost it.
                  • peste
                    • Dec 2016
                    • 12811
                    • ROMANIA
                    read..https://www.badcaps.net/forum/troubl...before-posting
                    • soul299
                      • Aug 2023
                      • 38
                      • Philippines
                      MODEL" AN515-44-R7ZU
                      Serial number : NHQ9MSP0081040D64D3400
                      SNID" 10405486134
                      can you help me sir?
                      • jeisson
                        • Jun 2019
                        • 4
                        • colombia
                        SNID" 10405486134
                        BIOS WEB ACER WORKING
                        • pityulix
                          • Nov 2021
                          • 28
                          • Targu-Mures
                          Hi,i need some help with bios.Fans full speed,no post,no caps,voltages ok,i think its not original bios,or its corrupted,can i ask for a new cleanme bios?Thanks.
                          Acer AN515-44-R0XU
                          SN: NHQ9HEX00S05201E5D3400
                          Model: N20C1
                          CPU AMD Ryzen GPU GTX
                          Motherboard: FH51S LA-K181P Rev.1.0
                          • volinakis
                            • Jan 2021
                            • 2733
                            • N/A
                            Acer AN515-44-R0XU
                            Model: N20C1
                            1st: AMD platform laptop does not have Intel ME_Region so it can't be "cleanme".
                            2nd: your bios backup has errors, look at compression 16,8MB to 1KB. Read bios chipset again, 3-4 times and compare results, when you have 2 identical it means you have a good backup.
                            • pityulix
                              • Nov 2021
                              • 28
                              • Targu-Mures
                              Thank you for respons,i fixed it,replaced the bios chip,now working fine.
                              • pityulix
                                • Nov 2021
                                • 28
                                • Targu-Mures
                                Thank you for respons,i fixed it with other bios chip,i made some mistake when i saved that bin,now its working fine with new bios chip.Thank you anyway for your time.The bios chip works with 1.8V,succesfully burned it with 3.3v programmer,changed with other and programmed it with 1.8v,probably when i tried to save the bin got faulty,next time i will be more carefull(i'm learning) πŸ™‚
                                • volinakis
                                  • Jan 2021
                                  • 2733
                                  • N/A
                                  yep, good news, enjoy. Only now you have other's serial machine and his win key I guess you used bios file from post 13.
                                  • pityulix
                                    • Nov 2021
                                    • 28
                                    • Targu-Mures
                                    I had a similar faulty laptop and taken from there,i changed the case,so it's like factory one πŸ’ͺ😁Cheers
