Fujitsu newer 6x4 BIOS master password (U758)
This topic is closed.
  • thenice2021
    • Mar 2021
    • DE
    Hello!
    Does anyone have a clue how to calculate the newer Fujitsu 6x4 master passwords starting with "203c-d001" (for example 203c-d001-2f2e-2878-d5dc)? on Lifebook U758?
    The Python tool crashes with an error (ValueError: invalid literal for int() with base 10: 'd0012') and as far as I unterstand it strips the 4 first characters (first block) containing the one and only hex/alpahnumerical char.
    So it expects only numbers in
    Code:
    numbers = (int(code[0:5]), int(code[5:10]), int(code[10:15]), int(code[15:20]))
    I already tried several combinations of converting the blocks from hex to dec, putting only the last 16 chars directly into the array etc. but no success.
    Since it's known that the resulting password is in the same scheme (also 8 chars alphanumerical), my hope is that the used XOR key is also the same.
    I attached a dump of my BIOS ver. 1.19. It is an InsydeH2O BIOS.
    Thanks!
    TNI
  • thenice2021
    • Mar 2021
    • DE
    Re: Fujitsu newer 6x4 BIOS master password (U758)
    Hi again,
    my new idea is - since it is still possible to boot an OS - to overwrite the BIOS without passwort clearing all the settings.
    But: DeskFlash, the utility provided by Fujitsu, denies the /PWD param apparently if there is a password set already.
    My hope is that the DOS version doesn't do this and there is a chance that this is indeed the case: http://d-minds.com.ar/documents/blog...e-h2o-efi-bios
    But it looks like the default setting for Lifebooks this age is that only UEFI boot is possbile. And I didn't find a way to boot FreeDOS in EFI mode yet
    It seems that it is possible to use "H2OFFT-Wx64.exe" in same way as the Fujitsu provided "H2OFFT-D.exe" and modifying params from an INI file to eliminate the password. But Fujitsu delivers DeskUpdate instead ...
    https://morethanpatches.com/2019/05/...syde-firmware/
    Does anybody know if "H2OFFT-Wx64.exe" does also work with Fujitsu and where to get it from?
    Thanks,
    TNI
      • 22089
      use the fujitsu unlocker tool https://www.badcaps.net/forum/showthread.php?t=79974 .
      http://dogber1.blogspot.com/2009/05/...ered-bios.html
      • thenice2021
        • Mar 2021
        • DE
        Thanks for your reply but this does not work with the newer scheme. It's the same script.
        • enezer1970
          • Aug 2021
          • France
          Hi
          Did you find any solution for that script ?
          Are you able to handle 6x4 hex hashes ?
          Eric
          • evserv
            • Jun 2014
            • 362
            • Russia
            Yes, there is a solution, but it is not freely available.
            • enezer1970
              • Aug 2021
              • France
              Do you have any recommended web site for that ?
              • evserv
                • Jun 2014
                • 362
                • Russia
                According to the rule of the forum, I cannot provide links to paid services.
                Search the internet.
                  • 22089
                  Search the internet,there are many paid services out there.This site is for free help only and links and recommendations to paid password services are not allowed.
                  If the Fujitsu-Unlocker doesn`t work,go somewhere else. https://www.badcaps.net/forum/showthread.php?t=79974
                  As there is no free solution at the moment for the newer algorythm and QR code
                  passwords this thread is closed.
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 โ€“ Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    BIOS access (F2) and Boot Menu (F12) are no longer possible โ€“ the system instantly reboots after the rollback messages.
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • macabook
                    ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
                    by macabook
                    Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
                    ๐Ÿงฉ Initial Issue
                    07-24-2025, 02:17 PM
                    Fujitsu LIFEBOOK U758 Notebook U Specification for Upgrade or Repair
                    This specification for the Fujitsu LIFEBOOK U758 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the U758 boardview and U758 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...
                    09-06-2024, 06:11 AM
                  • MohammedBathabet
                    Request BIOS dump for Fujitsu LIFEBOOK AH47/J (DAFH6BMB6A0)
                    by MohammedBathabet
                    I need a BIOS dump file for my Fujitsu LIFEBOOK AH47/J laptop.
                    Motherboard model: DAFH6BMB6A0
                    The system BIOS got corrupted and now the laptop powers on but does not boot.
                    I already tried the official Fujitsu support site, but the downloadable BIOS is only in .exe format and does not contain the raw .bin file needed for programming the BIOS chip directly with a programmer (CH341A).
                    If anyone has a working BIOS dump (.bin) for this model, please share it.
                    Thanks in advance!...
                    09-24-2025, 05:59 AM
