HP ProBook 650p G1 bios
  • indyga
    • Jul 2020
    • 42
    • Greece
    Greetings to all,
    i have a HP ProBook 650p G1 with S/N 5CG5490H64 and P/N P4T25EA
    The motherboard is 6050A2566301-MB-A04
    The machine starts fans are spinning and starts over again with no display but fans spinning again and again.
    I tried some other bios but with no luck only the power light works and nothing else. The problem seems that is the bios.
    Does any has a working bios? I am also attaching the current bios in case that anyone can help me.
    Thanks in advance for your time.
  • peste
    • 13924
    • ROMANIA
    Re: HP ProBook 650p G1 bios
    Originally posted by indyga
    Greetings to all,
    try..
    • indyga
      • Jul 2020
      • 42
      • Greece
      Originally posted by peste
      try..
      Dear friend thanks for your reply.
      I tried the bios but the result is the same as before....
      • peste
        • 13924
        • ROMANIA
        try..
        • indyga
          • Jul 2020
          • 42
          • Greece
          try..
          The same behaviur as before......
          • peste
            • 13924
            • ROMANIA
            try..
            • indyga
              • Jul 2020
              • 42
              • Greece
              try..
              no luck again.....
              • studdy05
                Bricked HP Probook 450 G7 Bios questions
                by studdy05
                Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                Ive got...
                07-08-2025, 09:24 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • the_raz
                Need (unlocked) bios for HP Probook 450 G3 Notebook
                by the_raz
                I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                Laptop number 1:
                Model: HP ProBook 450 G3
                Motherboard part number:...
                12-17-2024, 03:37 PM
              • istvanszasz99
                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                by istvanszasz99
                Product ID: RZ09-0421
                Motherboard: CH580
                Bios File Size: 32,768 KB
                Dear Forum Readers!
                !!! MY RAZER BLADE...
                11-24-2025, 05:52 PM
              • emil_t
                RTX3090 working fine but fans not spinning
                by emil_t
                Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                04-12-2024, 06:54 AM
