Re: MacBook Air 2017 A1466 EMC 3178 820-00165-A No power
Hi vesko356 hoppely you can me help i hope so much thanks for you time bro
Her is the link to download the Original backup
https://drive.google.com/file/d/10P4...w?usp=drivesdkLeave a comment:
Originally posted by ssio187ddHi,
Macbook Air 2017 A1466
EMC 3178
820-00165-A
SN: FVFVV003J1WM
Locked efi
please help me need urgent file to unlock and flash the efi chip
ssio187dd is online now Report PostLeave a comment:
EMC 3178
820-00165-A
SN: FVFVV003J1WM
Locked efi
please help me need urgent file to unlock and flash the efi chipLeave a comment:
Can you tell me if this EFI is specific to the 2017 EMC 3178 or is this for any 820-00165 board? I have an EFI ROM file from a 2015 board and it doesn't start up on my 2017 board. I have heard that the EFI for this model is specific to the 2017. Can someone confirm this either way?Leave a comment:
try..Attached FilesLeave a comment:
Hey guys am still in need of help if anyone has any ideasLeave a comment:
post serial number S / NLeave a comment:
hi guys i got a 1466 820-00165a with no fan spin and amber led on charger . the cpu warms up too but not powering up and does draw current.
i read spi but cant find file that matches my backup .00000000- 000FDFF0 ARE ALL F(ÿ)Attached FilesLeave a comment:
buddy,
pulsing could also be an failuren with clock chip, check volatges, check Rails!!!
if you dont know which rails, ask for help!!!Leave a comment:
Not workingLeave a comment:
Ok. This is the two dump.Leave a comment:
What was pulsing on / off?
Please post more details.
Very possible that you have a defective battery.
Restore your bios and post your voltage rail that is pulsing.Leave a comment:
Did you make a bios backup before you started ? .MEInject isn`t recommended for anything over ME 6 in my opinion,and certainly shouldn`t be used with apple ME fw . Post the original bios backupLeave a comment:
Hi, I' ve this MacBook Air with a strange problem. This laptop come in to my shop with initial problem PULSING (ON/OFF, no fan)
I wrote this attached bios dump that I clean me region by ME INJECT software and Macbook Power on but have a strange defect.
The Macbook Power on only when I connect the AC adapter without battery. It Never power on by clicking power key on keyboard. I also tryed to power on by SMCbypass on the motherboard.
When Macbook is ON and I press ON/OFF key the macbook go off without problem
I tryed to clean me region using FIT but I can't find efi payload for this model MBA7,2.
Can anyone help me?Tags: None
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? -
Hi everyone.
Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....04-15-2024, 01:24 PM -
by sherifuHello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...1 Photo
by ACS-RepairI'm hoping someone can help me with a 2017 MacBook Air A1466 820-00165 that is running very slow. This is a board that I picked up on ebay recently.
This is not being caused by a sensor issue. All sensors report normal operation and the fans run at normal speed. Geekbench gives me a single core CPU value of 124, when it should be closer to 400. I was unable to complete an install on the SSD without putting it into a different computer first.
The board appears clean with no sign of liquid damage. I have done a PRAM and SMC reset, and I have done a reflow of the SMC. I have inspected... - Loading...
