Hp Bios Need DAG7ALM8C0 Rev C
    Originally posted by danito View Post
    try
    Thanks bro this works great
      dag3mrmbac0 rev c org old backup bios bin
        CAN ANYONE HELP ME OUT WITH THE COMPLETE GOOD FILE
        Upload old file and serial number and the problem of your laptop
          Hello Friends
          Can someone help me to fix this bios ( start then balck screen)
          Model : 14-ce3501na
          motherboard : DAG7ALMB8C0 REV:C
          serial number : 5CD951C71M
          thank You in advence
          Last edited by webhost; 07-23-2024, 04:41 AM. Reason: forget writing serial number
            Originally posted by webhost View Post
            Hello Friends
            Model : 14-ce3501na
            Use the guides linked in this post to ID your bios and extract the update from HP https://www.badcaps.net/forum/troubl...95#post1839395
            (your BID is 086AA)
            When you have the new bios use a hex editor to copy your DMI (serial,feature byte,win key) from your backup to the new bios. The offsets are the same as in that post 400000 - 40403F
              (your BID is 086AA)
              i'am Biginner i'am not able to do this operation
                You`ll always be a beginner until you try. Search the forum for 086AA https://www.badcaps.net/forum/troubl...-c#post3208126 .There`s a virgin bios, try it.If its working with that bios we can add the DMI later
                  i flashed this bin bios but stii power with blackscreen
                    You could try some older bios versions, but for that you`ll have to extract them yourself using the guides. There`s around 15 older bios versions at HP support. If an older bios version also doesn`t work i`d say you have some sort of hardware problem.
                      i need this bios please send this ASAP
                      thnq for your help.
                        thnq for your help.
                        post the S/N, the original bios of the laptop, the motherboard model, the full name and model of the laptop,etc.
                          sir i need bios DAG7ALMB8C0 REV C HP-14CE3065TU S/N 5CD02739YW....PLZ HELP
                            Post your bios backup
                              SIR I'M UNABLE TO ATTACHED THE BIOS FILE..HOW CAN I SEND
                                SMDFlea commented
                                Editing a comment
                                Put your file in a zip or rar and add to your post as an attachment.
                              #76
                              thanks sir ...this is the file sir i need bios and ec also sir
                                Hp pavilion 14-ce3600sa
                                SN; 5CD00113L6
                                Problem ; NO Display
                                  SN; 5CD00113L6
                                  you have everything you need at post #2..
                                    Hi colleagues. I have made the respective measurements and everything is ok. Help me with this attached bios. model hp 14-ce3014la serial 5CD0436WDZ
