hello guys i have a dump need to be clean i try with hex but nothing still asking for pin code Thanks
Macbook air 2011 Need clean my dump
by _CupaDear community,
this is my very first post, I am quite new to macbook repairs, and I am excited:-)
I have a 2011 MacBook Air 13' that does not power on. No fan spin, nothing.
Here are the specs:
MacBook Air Mid-2011
CPU: 1.7 GHz Core i5 (I5-2557M)
Model: A1369 (EMC 2469)
RAM: 4 GB
VRAM: 384 MB
The first question:
Unfortunately, it came with a 'fake' power adapter which seems not to talk to the computer. Sometimes it does show green light immediately after connecting it to the board,... -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by yura8Hi there! I have not so usual situation...
I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
P.S. If you have else any ideas about repair, or you had a similar...-
Channel: Schematics and Boardviews
12-20-2024, 02:31 PM -
by resistor83Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
I thought it was a screen problem but after changing it the problem remains.
What could I do? - Loading...
