Hi, I wanted to share a working bios for HP 15s-eq0002nk Ryzen 5 Radeon Vega Graphics BoardID DA0P5EMB6E0 Rev E.
Tags: None
Re: need DA0P5EMB6E0 rev E ec file
DA0P5EMB6E0 rev E (tệp EC)
From this topic : https://www.badcaps.net/forum/showthread.php?t=92745Attached Files↵
https://www.badcaps.net/donateComment
Here it is backup BIOS for:
HP Laptop
Model: 15s-eq0024ur
ProdID: 9QZ51EA#ACB
RMN: TPN-Q230
Mainboard: DA0P5EMB6E0 REV:E
Downloaded with black colored CH341A Programmer
Attached FilesLast edited by McAlister; 03-14-2025, 04:57 AM.Comment
BID : 086FD
AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...-
Channel: Schematics and Boardviews
10-01-2024, 01:07 PM -
AMD Radeon R9 290 / R9 380 / R9 390
The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...-
AMD Radeon RX 470 / RX 580 Schematic & Board View
The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...-
AMD Radeon R7 340 / R7 430 Schematic & Board View
The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...-
10-01-2024, 12:36 PM -
AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...-
- Loading...
