HP 15s-eq0002nk Ryzen 5 Radeon Vega Graphics BoardID DA0P5EMB6E0 Rev E
  • stuntgp2000
    • Dec 2018
    • 4
    • Morocco
    Hi, I wanted to share a working bios for HP 15s-eq0002nk Ryzen 5 Radeon Vega Graphics BoardID DA0P5EMB6E0 Rev E.
  • roml
    • Feb 2012
    • 11
    Re: HP 15s-eq0002nk Ryzen 5 Radeon Vega Graphics BoardID DA0P5EMB6E0 Rev E
    Thanks friend.Working Bios dump
    • Jaime78
      • Jul 2015
      • 8
      • Andorra
      Hi, thanks, it works perfectly.
      • spider45
        • Mar 2019
        • 4
        • turkey
        need DA0P5EMB6E0 rev E ec file
        Hi guys i need a DA0P5EMB6E0 rev E (EC file)
        • hoaca388
          Badcaps
          • Jan 2022
          • 11711
          Re: need DA0P5EMB6E0 rev E ec file
          DA0P5EMB6E0 rev E (tệp EC)
          From this topic : https://www.badcaps.net/forum/showthread.php?t=92745
          • mma
            • May 2022
            • 2
            • saudi arabia
            hello guys
            i asked for signature file not found.
            how to fix pls?
            • mma
              • May 2022
              • 2
              • saudi arabia
              my hp laptop stop working because of bios upgrade failure and i can not fix.
              please help
              • alexplamkop
                • Feb 2023
                • 10
                • thai
                thank a lot
                • ismaelstepheno
                  • Jun 2020
                  • 226
                  • UE
                  Thank you
                  • topline
                    • May 2013
                    • 11
                    • italy
                    thank ... is good tested is ok
                    • McAlister
                      • Mar 2025
                      • 4
                      • Kazakhstan
                      Here it is backup BIOS for:
                      HP Laptop
                      Model: 15s-eq0024ur
                      ProdID: 9QZ51EA#ACB
                      RMN: TPN-Q230
                      Mainboard: DA0P5EMB6E0 REV:E
                      Downloaded with black colored CH341A Programmer
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11711
                        HP Laptop
                        Model: 15s-eq0024ur
                        ProdID: 9QZ51EA#ACB
                        RMN: TPN-Q230
                        Serial number ?
                        • McAlister
                          • Mar 2025
                          • 4
                          • Kazakhstan
                          Originally posted by hoaca388
                          Serial number ?
                          S/N#: 5CD047GPB7
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11711
                            S/N#: 5CD047GPB7
                            BID : 086FD
                              AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                              The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                              10-01-2024, 01:07 PM
                              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                              10-01-2024, 12:46 PM
                              AMD Radeon RX 470 / RX 580 Schematic & Board View
                              The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                              10-01-2024, 12:52 PM
                              AMD Radeon R7 340 / R7 430 Schematic & Board View
                              The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                              10-01-2024, 12:36 PM
                              AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
                              The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
                              10-01-2024, 12:20 PM
