Hp 250 G5 only showing power and Charging LED
  • Chandaj
    • Aug 2020
    • 40
    • ZAMBIA
    HI, after bios up my hp 250 G5 only showing power LED and charging LED
    i have tried many bios bins but with no success. Kindly help
    Motherboard Model..
    Bdl50 la-d703p rev 3.0
  • peste
    • Dec 2016
    • 13678
    • ROMANIA
    Re: Hp 250 G5 only showing power and Charging LED
    Motherboard Model..
    post the backup of the bios, the original bios of the laptop.
    • Chandaj
      • Aug 2020
      • 40
      • ZAMBIA
      Attached is the back up bios
      • peste
        • Dec 2016
        • 13678
        • ROMANIA
        the posted bios is almost empty..read the bios chip again and post ..
        • Chandaj
          • Aug 2020
          • 40
          • ZAMBIA
          That's the backup copy i made before flashing the bios, that's why i need a new bios bin file
          • peste
            • Dec 2016
            • 13678
            • ROMANIA
            try..if it doesn't work, post the full name and model of the laptop
            • Chandaj
              • Aug 2020
              • 40
              • ZAMBIA
              Hello, Thanks for the feedback still having problems, attached are the full specifications of the laptop.
              Thanks in advance.
              • Omar Villalba
                Omar V23
                • Jun 2025
                • 11
                • Paraguay
                Hello, good day,
                I'm looking for the BIOS for the following device:
                • Model: HP 250 G5 (W6C13LT)
                • Motherboard: BDL50 LA-D703P rev. 3.0
                Would anyone be able to share it with me?
                • peste
                  • Dec 2016
                  • 13678
                  • ROMANIA
                  Originally posted by Omar Villalba
                  Hello, good day,
                  post S/N..product number,etc..
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • rob_hen
                    Dell XPS 13 9370 Laptop, No power, not charging
                    by rob_hen
                    Hello!
                    This is my first post for help, and I am quite newer to board repair, so bear with me.
                    I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                    After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                    There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                    My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                    05-01-2025, 09:20 PM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    by sam_sam_sam
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
