Acer v5-573g got extremely slow after BIOS flash
  • HisInfernal
    • Nov 2020
    • 4
    • Bulgaria
    Hello!
    I have acer v5-573g (i5-4200u, geforce 720m, 8gb ram).
    Couple of weeks ago I decided to modify a little bit BIOS configuration via EFI console (usb stick with efi boot with setup_var commands). So I bricked my laptop. Afterwards I disassembled it and desoldered BIOS chip (2MB one) and flashed it with usb programmer. There was no success and just after that I found that there is second BIOS chip, which is 4MB, so I disoldered it as well and flashed it as well.
    I was flashing BIOS from this thread: https://www.badcaps.net/forum/showthread.php?p=844418 (Aspire V5-573G bios needed). Archive contains 2 files, 2mb and 4mb.
    So basically I flashed both 4MB img -> 4MB chip and 2MB img -> 2MB chip.
    Now laptop boots but working extremely slow. BIOS POST is taking around 15 minutes, windows installing, only booting is taking around 10 minutes etc.
    Maybe there is something that I am missing or should do? I've tried to flash original BIOS from acer website from usb flash and both BIOSes were ok, they are ZRQ.fd (4.4MB size). But no success, laptop is extremely slow. So I dont know what exactly should I do anymore.
    Is there any way to fix it without desoldering chips again and even if I will desolder them what should I put on them ,since this BIOS that I've downloaded is only one that I was able to find.
    Any help?
    • 20888
    Re: Acer v5-573g got extremely slow after BIOS flash
    Post your original bios backups ,if you made any .
    • HisInfernal
      • Nov 2020
      • 4
      • Bulgaria
      Haven't made any... I flashed directly those 2 images (from other thread) over.
      • peste
        • Dec 2016
        • 12792
        • ROMANIA
        try these..I hope it helps ..
        • HisInfernal
          • Nov 2020
          • 4
          • Bulgaria
          Thank you! I will try them. Should I desolder chips and to program them or there is any way to flash them from some linux/dos tool, since device is working, just slow?
          • peste
            • Dec 2016
            • 12792
            • ROMANIA
            yes .. remove the chips from the motherboard ..
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • abhorsen
              Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
              by abhorsen
              Hey guys,
              Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
              Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
              Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
              07-06-2023, 10:22 AM
            • mrrubik
              Dell Optiplex 7010 micro bad BIOS flash?
              by mrrubik
              Hi folks,
              I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
              After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
              Steps I took:
              1. Read BIOS with CH341a, verified hash twice
              2. Patched
              12-23-2024, 04:11 PM
            • AkaBukai
              Is it okay to flash stock bios onto the motherboard's BIOS?
              by AkaBukai
              Hi there,
              I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
              The little LED on the power button is flashing slowly and nothing happen.
              This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
              So I decided to flash the BIOS using a cheap programmer.
              And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
              I also...
              12-19-2024, 12:15 PM
            • James Jackson
              Panasonic CF-20G0247VM BIOS Bad Flash Help
              by James Jackson
              I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
              Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
              05-01-2025, 11:28 AM
