Lenono Legion Y545 Failed Bios Update. Program Chip?
  • bboyzell
    • Aug 2014
    • 20
    Hi Guys
    I purchased a Lenovo Legion Y545 (i7 9750 / RTX 2060)
    The previous owner he told me it failed a bios update.
    I thought cool i could use a simple EEPROM Programmer, nope
    I didn't realize that lenovo don't use EEPROM chips, but EC
    So from my findings i can use a Vertyanov Programmer, to reprogram my EC chip via the keyboard connection, but im not 100% sure on this
    The Mainboard in my legion is NM-C221 Rev2.0
    The Lenovo EC is
    IT8226E-192
    1919-BXA
    S16YSA
    L003
    i have been able to get my hands pretty easily on a the bios.bin, the machine also turns on with quick fan spin that stops and a blinking power button light.
    In Summary does the Vertyanov Programmer, Support the IT8226E-192?
    as from what iv seen it only mentions earlier versions of this chip.
    As i know the programmer needs the machine to power to be able to program, which this laptop meets that requirement
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: Lenono Legion Y545 Failed Bios Update. Program Chip?
    If it failed after a BIOS update you should try to flash the BIOS first, and if it doesn't solve it then you can try to flash EC.
    • bboyzell
      • Aug 2014
      • 20
      there is a separate bios chip to the EC?, i thought the bios was intergrated in to the EC
      I did tear it down and had a quick look couldnt spot anything resembling it
      Cheers
      • piernov
        • Jan 2016
        • 4436
        • France
        There's almost always a dedicated SPI ROM for BIOS. (except on the Apple T2 machines where it's stored on the SSD NAND chips)
        • bboyzell
          • Aug 2014
          • 20
          Bingo, Found the Chip W25Q80EWNIG 1.8v , now the drama of finding a bios dump thats usuable
          Im mostly finding dumps like this
          https://www.alisaler.com/legion-y545...1-rev2-0-bios/
          that are 8mbyte not /8mbit
          I did do dump using my CH341A, and have attached it .bin
          • bboyzell
            • Aug 2014
            • 20
            File Dump, Suspected corrupt
            • piernov
              • Jan 2016
              • 4436
              • France
              That's the VBIOS not the main BIOS.
                • 21040
                The bios chip is at UC3 ,check the schematic - https://www.badcaps.net/forum/showthread.php?p=1017588
                When you find it post the backup .
                • bboyzell
                  • Aug 2014
                  • 20
                  That would make sense..
                  ..now my 341 Programmer is giving me errors writting to it..
                  I have found the UC3 located just next to the m.2 slot.
                  once i have written the Vbios and put it back i will then do a dump of the bios
                  Chip number: 25B127DSIG
                  • bboyzell
                    • Aug 2014
                    • 20
                    from my googling the chip in the UC3 Position, is a Power IC
                    yet in the Y540 Schematic its mentions to be a W25Q128JVSIQ_SO8 at this position
                    • bboyzell
                      • Aug 2014
                      • 20
                      it has left my slightly confused as the model number has 127 in it, not 128 like most chips
                      • bboyzell
                        • Aug 2014
                        • 20
                        from my findings the 25B127DSIG is a SPI Bios Chip but of a lesser known brand
                        https://au.mouser.com/ProductDetail/...sTEejDYQ%3D%3D
                        Since my programmer doesn't want to read from it, might try and harvest a W25Q128 off an old dead laptop (have a few to pick from) and program and install
                        • bboyzell
                          • Aug 2014
                          • 20
                          So far iv been having a bit of luck
                          read and reprogrammed the bios "25B127DSIG"
                          set CH341A Version 1.18
                          i have attached the bios dump
                          Set it as Winbond W25Q128BV.
                          Now awaiting the 1.8v Adapter to reprogram the Vbios
                          Atm im still getting a blinking power light and a brief fan spin, then looking every 15 seconds
                          • bboyzell
                            • Aug 2014
                            • 20
                            So i have made a bit more progress now
                            https://forums.lenovo.com/t5/Gaming-...SB/m-p/5026109
                            It is possible to do a forced bios recovery via usb if you fail a bios update on your Y545
                            i have attempted this but still have no system up again going, i suspect playing with the vbios chip first didnt help..
                            but i am getting my 1.8v programmer in the next few days
                            i know no ones commenting but im still posting, the reason behind this is a bit of a log for people with the same machine, to get some ideas on what they can do
                            • bboyzell
                              • Aug 2014
                              • 20
                              At this point i have reverified that the bios and vbios chip have been programmed correctly
                              but at this point still no good.
                              i have since stopped working on it
                              • dlhxr
                                • Mar 2021
                                • 4
                                I have a Y540 and bios fails as welll after I downgrade from bhcn41ww. The one you post about usb bios recovery doesn't work for me as well. Do you have any progress on CH341A force flashing?
                                • Adiktus
                                  • Jan 2020
                                  • 13
                                  • Philippines
                                  I have a Lenovo Legion Y545 (clients laptop) same issue but GTX 1660Ti
                                  I already tested 5 version of bios...no change
                                  I manage to dump the W25Q80EWNIG but my 1.8v adapter needs to be replaced.
                                  I try to erase the bios then turn it on and the key fn and back light is not present meaning the bios is still working on a first phase? input output of Fn keys?
                                  any idea guys?
                                  • Adiktus
                                    • Jan 2020
                                    • 13
                                    • Philippines
                                    I managed to post the issue in the lenovo community the reply is so dodgy wahaha
                                    https://forums.lenovo.com/t5/Lenovo-...page=2#5737349
                                    • igeektech
                                      • Jul 2017
                                      • 18
                                      legion y545 bios repair help
                                      same issue as OP, turns on ,no image blinking power button led. attached is a dump of OG bios.
                                      S/N - pf1ysaqm
                                      mtm - 81q60002us
                                      • RJ_TECH
                                        • Jan 2022
                                        • 19
                                        • India
                                        S/N - pf1ysaqm
                                        mtm - 81q60002us
                                        Try
                                          Lenovo Legion Y545 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Y545 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Y545 boardview and Y545 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Legion Y545...
                                          09-06-2024, 02:30 PM
                                          09-06-2024, 02:28 PM
                                          09-06-2024, 01:21 PM
                                          09-06-2024, 08:38 AM
