Hp x360 11 g1 ee 6050a2881001-mb-a02
  • spendary
    • Nov 2016
    • 9
    • iraq
    Hello Dears
    i need Bios Dump for Laptop HP X360 11 G1 EE
    Board Number : 6050A2881001-MB-A02
  • peste
    • Dec 2016
    • 12880
    • ROMANIA
    Re: Hp x360 11 g1 ee 6050a2881001-mb-a02
    Originally posted by spendary
    Hello Dears
    bios extras din actualizarea site HP ..
    • spendary
      • Nov 2016
      • 9
      • iraq
      it did not work.
      the power led is on but there is no screen
      • Zeeshanali1
        • Oct 2018
        • 27
        • Pakistan
        unpass is clean me..............
        zash
        • mahlcom
          • May 2020
          • 12
          • algerie
          Board Number : 6050A2881001-MB-A01
          • peste
            • Dec 2016
            • 12880
            • ROMANIA
            try post #2, but don't forget to make a copy of the original bios of the laptop..
            • Wilfried
              • Sep 2019
              • 81
              • Cameroun
              good evening I have my HP probook x360 11 g1
              who has a problem
              when i put a hard drive with the operating system inside it never comes to desktop
              it stalls on the repair page
              please help me fix this bios file
              6050a2881001-mb-a01
              • peste
                • Dec 2016
                • 12880
                • ROMANIA
                who has a problem
                6050a2881001-mb-a01
                try post #2
                • Wilfried
                  • Sep 2019
                  • 81
                  • Cameroun
                  Thanks 👍👍 very good
                  • kingkong computers
                    • Sep 2018
                    • 193
                    • pakistan
                    plz unlock bios password
                    • testinglaptops
                      • Oct 2022
                      • 76
                      • United Arab Emirates
                      ThankYou Worked For Me in 2024
                      • Ac chinedum
                        • Nov 2023
                        • Nigeria
                        PASSWORD REMOVAL 6050A2881001 MB A01
                        • peste
                          peste commented
                          Editing a comment
                          post merged..
                      • peste
                        • Dec 2016
                        • 12880
                        • ROMANIA
                        post the S/N, post the original content of the bios chip, even if it is corrupted..the full name and model of the laptop,
                        ​etc.
                        • igragon08
                          • Sep 2022
                          • 38
                          • madrid
                          Could someone fix my BIOS .bin file problem? The problem I'm having is that I replaced the motherboard in my HP ProBook x360 11 G1 EE with a new one. Since I'm a newbie and still learning, I did it wrong. I left out several pieces of information, such as the feature byte and the build id. The motherboard is no longer in programming mode, and I can't do anything. I've tried software like HP DMI NBDmiFit, but no matter how many videos I've watched and read here on your forum, I haven't been able to get it to work. It doesn't detect the flash drive in fat32, as some programs request, and the BIOS is EFI, and I don't know. I would need help from someone who could give me a link to see the steps in detail because, no matter how much I've tried, I haven't been able to.
                          The problem is that the PC turns on and displays two errors on the screen related to missing data and that the motherboard is incorrectly programmed. Then you continue and the PC boots normally and perfectly. I can even enter the PC's BIOS and see the missing data (screenshot attached). The problem is that I would need to go back to programming mode and enter the missing data so that it doesn't show errors at startup. The full details are as follows:
                          Serial Number: 5CG82606KT
                          Product Number: 1LT66ES
                          Description: HP ProBook x360 11 G1 EE
                          Build ID: 16WWAUDT601#SABE#DABE
                          Feature Byte: 3X476J6Z6b7B7H7M7R7W7s9AaBaQapaqauawbVbhcAd6dUdWdpdqgd.rT
                          Motherboard CT: PGHFD00WB8702B
                          Motherboard revision: autoboot 6050a2881001-mb-a02
                          BIOS chip: Winbond W25Q64FW (64Mbit / 8MB)
                          Clean ME region: ✅ (I still don't fully understand this, but I think I need to clean the region based on what I've read in so many posts)
                          If anyone can help me, I'd appreciate it. I've attached the .bin file.
                          Best regards.​
                          • volinakis
                            • Jan 2021
                            • 2741
                            • N/A
                            Originally posted by igragon08
                            Best regards.
                            use BCU (BiosConfigurationUtility) under cmd. Just google "BiosConfigurationUtility" and you'll find it. After install open cmd as Admin, goto folder where is installed and use cmd line: "biosconfigutility /get:1.txt". Open 1.txt file with text editor, fill blank fields with your DMI, save as 2.txt in BCU folder (save it in Docs then move it to BCU) then use cmd line: biosconfigutility /set:2.txt
                            • igragon08
                              • Sep 2022
                              • 38
                              • madrid
                              I forgot to mention that I have also used that BCU option, I have read the manual so many times and tried to do it under cmd as administrator but it always gave me an error, that I could not write the data when doing the set..xxx, I tried under administrator and running cmd normally but nothing, without success, thanks anyway for mentioning it, I think the only option would be under some software like NBDmiFit but I can never unlock the motherboard and put it back into programming mode, I think HP has some kind of lock internally for that and it is difficult to unlock it, I even think after so many tests that I have done that the only option is flashing, prepare a . bin from mine and put my data in the correct place and flash again ... let's see if someone else can shed light on us,
                              Thanks a lot for commenting volinakis, let's see if someone can help us ...
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11813
                                If BCU fails, use manual method, restart counter until it reaches 0
                                • igragon08
                                  • Sep 2022
                                  • 38
                                  • madrid
                                  Hi hoaca388, thanks for responding. Could you tell me what you mean by the manual method and resetting the counter to zero? I know I've tried several tests and methods, but I can't quite figure out what you're referring to. Could you be more specific, since I'm still learning from you? I'm a bit of a novice and still need a little more precision in the steps.
                                  Thanks.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11813
                                    Thanks.
                                    When you flash the unlock file is DMI lost ? You have to add DMI again by : using BCU or you will see a counter, restart it until it reaches 0 then do the required steps.
                                    • igragon08
                                      • Sep 2022
                                      • 38
                                      • madrid
                                      You have to forgive me but I don't understand exactly what you're telling me hoaca388, what I've tried with the BCU program under windows is once you configure the "bcuconfig....get..." (I don't remember exactly how to write it) it generates a file where all the bios data appears in . txt format, well I see that in that file both the feature byte and the build id are blank and the MTM is in *lock mode, from what I've read you should put the missing data in their correct places and then do the "bcuconfig....set", but it gives me an error because it tells me that the MTM is in *lock mode, well, I've tried to only change the . txt file read from the bios info in MTM from lock to *unlock to see if the mode is unlocked and you can program it again (I've done it by putting the data that I was missing and even just by changing MTM to *unlock) and it always gives me an error and doesn't let me do anything or enter the data or change to *unlock mode, in cmd it always gives me an error both in admin and normal mode and there is no way I can do anything, that's why I come to you...
                                        HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                        09-07-2024, 05:50 AM
                                        HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-06-2024, 03:30 PM
                                        HP Pavilion x360 Pavilion x360 - 15-dq1004na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion x360 Pavilion x360 - 15-dq1004na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 15-dq1004na boardview and Pavilion x360 - 15-dq1004na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-06-2024, 12:18 PM
