Bios password dell latitude 5511 - 8FC8
    Hi all, i need a bios for FDV50 LA-J281P Rev:1.0 S.TAG is JX10M73
    • Vesko356
      Vesko356 commented
      Editing a comment
      Read the rules before posting
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • Name your thread with make, full model numbers and request
      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Dell Model : Dell Latitude 5501
    Service Tag: JX10M73
    need a bios pls
    • Vesko356
      Vesko356 commented
      Editing a comment
      Service tag JX10M73 match Dell Latitude 5511, not 5501!
      You MUST:
    Dell Latitude 5511 FDV50 LA-J281P Rev:1.0
    late display bios issue
    can u someone help me to clear this bios issue pls.
    Last edited by Vesko356; 02-24-2024, 06:41 AM. Reason: Attached bios removed, already posted above!
      try
        Thank you, It started fast booting, but unfortunately it is holding a password. Could you help me to clear that password also?
          next time describe all the bios problem before posting.
          1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
            Thank you very much, but I couldn't find the absolute disable option, and now it works fine.
              I learned how to flash. Pretty sure I got the right flash. Tried it multiple times, and then realized there were two other chips on the board that were the exact same as the one I was flashing. This was two years ago and all is forgotten.
              I just wish I could get the password. And if not, maybe a good Rom or whatever and which chip is the right one to flash?
              Any other help would be greatly appreciated.
              J
              • peste
                peste commented
                Editing a comment
                merged post..
              #29
              If you need my bios, I can try and see if I can do it. Like I said... I don't know which chip is the right one to connect too.
                read the rules..https://www.badcaps.net/forum/troubl...before-posting
                post the full name and model of the laptop, motherboard model, original bios. Service Tag, etc..
                  kindly help in removing 8FC8 password for Latitude 5511 with service Tag GRBDGB3, dump attached.
                    Unlocked File try ... Good luck
                      Thank you, it worked
                        Dell latitude 5511
                        ST : 70fq493
                        Problem : restarting problem
                          greetings
                          Please can you help me with my bios to repair it, it does not give video, my motherboard is LA-J282P, my service tag is 34ZG4D3
                          my team 5511
                          Please with other bios here if it gives video but it does strange things
                            BIOS Password Dell Latitude 5530 2JNWRL-8FC8 .Can someone help me please
                              post dumb and snid
                                Off topic, read the thread title please, this topic is for the latitude 5511 .Use the forum search engine to find a related Latitude 5530 topic and post your request there. If you can`t find one then start your own thread, posting your service tag and backups, as per the forum rules https://www.badcaps.net/forum/troubl...before-posting
                                  Originally posted by shiyab View Post
                                  post dumb and snid
                                  NO , it is off topic !!!!!!!!!!!!!!
                                    dell precision 3551
                                    fdv50 la-j281pJ7C93
                                    st-1YJ7C93
                                    no display pls help.clean this
                                      SMDFlea commented
                                      Editing a comment
                                      Off topic, this thread is for the latitude 5511 as it says in the thread title.
