X250 with bios lock
  • douha
    • Sep 2014
    • 44
    • maroc
    #41
    Re: need to pach this file lenovo x250
    Hi freind
    I cant modify any thing in setup becaus is disabled
    I read the bios with rt809h i write it but alwas ask me for password when i press enter in keyb i access to setup but we cant change any value
    • douha
      • Sep 2014
      • 44
      • maroc
      #42
      Re: Help to patch bios lenovo x250
      Originally posted by Mazorca
      Try it now, instructions inside. Follow them closely. I've done several x250's and all worked. Remember to put the backplate or bottom after writing the patch, no batteries. I think there is a small switch that needs to be pressed, putting the backplate will solve that.
      Pleas freind can you help me to solve my labtop
      • douha
        • Sep 2014
        • 44
        • maroc
        #43
        Solved many thank's
        • douha
          • Sep 2014
          • 44
          • maroc
          #44
          Help to patch lenovo x250
          Hi help to disable password for 2 labtop
          X250
          I patch some bios with lenovo patcher an python 3.7
          But i"m not lucky to patch this 2 pc
          Pleas any one can patch it for me
          Thanks freind
          • ifixeth
            • Jun 2021
            • 4
            • ethiopia
            #45
            solved for me also need close back cover tnx
            Originally posted by douha
            Solved many thank's
            • jougounou
              • Jul 2014
              • 185
              • niger
              #46
              Levovo x250 viux1 nm-a091 rev:1.0 unlock password
              Hello
              need help to unlock my x250 bin pls
                • 20300
                Re: Levovo x250 viux1 nm-a091 rev:1.0 unlock password
                Originally posted by jougounou
                Hello
                There is no need to make a new thread when there are other X250 threads where you can post your request.
                Havn`t you tried the lenovo Autopatcher,or checked for a prepatched bios ?
                https://www.badcaps.net/forum/showpo...42&postcount=4
                You MUST:
                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                • Ballou
                  • Jan 2023
                  • 4
                  Need help to unlock TP X250 Bios
                  Hello everybody,
                  i got a used a Thinkpad X250 and dont have the Bios pw. Attached is the Bios dump. Does anybody have a tip? Thank you in advance
                  Felix
                  • Markus1741
                    • Sep 2020
                    • 842
                    • N/A
                    #49
                    Re: Need help to unlock TP X250 Bios
                    Originally posted by Ballou
                    Hello everybody,
                    Felix
                    Hello read this ...
                    https://www.badcaps.net/forum/showpo...52&postcount=1
                    and her is your patched file ...
                    Good luck
                    • Ballou
                      • Jan 2023
                      • 4
                      Re: X250 with bios lock
                      Hello Markus,
                      thanks a lot! Awesome.
                      Greetings to Bavaria ;-)
                      • meowmeow123
                        • Nov 2023
                        • PH
                        #51
                        I am newbie, i just bought x250 to my surprise it is bios lock how to remove the password, can i used the patched bios here posted and how to flash,
                        Please help thanks
                          • 20300
                          Please help thanks
                          https://www.badcaps.net/forum/showthread.php?t=103526
                          • Mrówa112277
                            Mrowa7711
                            • Jan 2024
                            • 5
                            • Polska
                            #53
                            Good morning, please help me, I'm a beginner. Lenovo x250 with bios password. I read the original bios using ch341a, used the autopatcher and everything was fine. I uploaded it, after turning it on I have 2 x 5 signals and after 2 minutes the board turns off. what am I doing wrong?
                            • Vesko356
                              Vesko356 commented
                              Editing a comment
                              Thread merged.
                              Read the rules before posting!
                              You MUST:
                              • Post under a related thread if it exists
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                          • Mrówa112277
                            Mrowa7711
                            • Jan 2024
                            • 5
                            • Polska
                            #54
                            lenovo ThinkPad x250,
                            type 20CL-S5T900
                            s/n 09G0MG 15/12
                            VIUX1 NM-A091
                            REV 1.0
                            17.04.2013
                            • Vesko356
                              Vesko356 commented
                              Editing a comment
                              Originally posted by Mrówa112277
                              prosba o wsparcie
                              Post in English only please!
                          • idrisso
                            • Jun 2022
                            • 6
                            • morocco
                            #55
                            i have password on lenovo x250 need patch thanks
                            • Vesko356
                              Vesko356 commented
                              Editing a comment
                              You MUST:
                          • macak
                            • Aug 2024
                            • deutchland
                            #56
                            I have password on lenovo x250 need patch thanks
                            type 20CL-S4UK00
                            s/n PC-092EFC 15/11
                            VIUX1 NM-A091
                            REV 1.0
                            17.04.2013​
                              • 20300
                              type 20CL-S4UK00
                              s/n PC-092EFC 15/11
                              VIUX1 NM-A091
                              REV 1.0
                              17.04.2013​
                              Have you tried the lenovo Autopatcher,or checked for a prepatched bios ?
                              https://www.badcaps.net/forum/showthread.php?t=103570​
                              • Rekoo1997
                                • Oct 2018
                                • 22
                                • Egypt
                                #58
                                viuxi nm--a091 rev1.0
                                Intel Core i5-4300U
                                black screen
                                this file old bios
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged..
                              • peste
                                • Dec 2016
                                • 12241
                                • ROMANIA
                                #59
                                Intel Core i5-4300U
                                black screen
                                this file old bios
                                post S/N, full name and model, etc.
                                • Rekoo1997
                                  • Oct 2018
                                  • 22
                                  • Egypt
                                  #60
                                  the serial number is erased from device
                                  lenovo think pad x250
                                  Intel Core i5-4300U​
                                  • ArtMov
                                    [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                    by ArtMov
                                    Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                    1. I made overclocking lock disabled the default in amibcp
                                    2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                    03-31-2023, 01:30 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • BrentH561
                                    Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                                    by BrentH561
                                    Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                                    Here is the hardware identification specs:
                                    HP EliteDesk 800 G6 SFF
                                    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                    Serial No: MXL1223499
                                    Product No: 26S74UT#ABA
                                    BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                                    08-23-2024, 08:36 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
