Inspiron 14 3476 Vegas Turis MLK KBL-R 17841-1
  • Zaraki7777
    • Sep 2017
    • 173
    Dear Friends,
    I need bios for Dell Inspiron 14 3476 Vegas Turis MLK KBL-R 17841-1 WX2RR.
    Thanks in Advanced,
  • peste
    • Dec 2016
    • 13439
    • ROMANIA
    Re: Inspiron 14 3476 Vegas Turis MLK KBL-R 17841-1
    Originally posted by Zaraki7777
    Dear Friends,
    Thanks in Advanced,
    try..
    • Zaraki7777
      • Sep 2017
      • 173
      Thank you so much, I will test it.
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Try
        Factory Made Last Version
        Supported Dell Inspiron 3476/3576 and Vostro 3478/3578
        • Zaraki7777
          • Sep 2017
          • 173
          Thank you so much its works
          • cristiannec
            • Oct 2014
            • 49
            • Italia
            Originally posted by qayyum786
            Try
            Works but i experience a wierd problem.
            After i write it, pc starts in factory mode, recognises and charges battery.
            As long as i use it in factory mode it charges battery fine
            After i select model, vostro/inspiron 14/15, it says battery is not recognised or not dell genuine.
            Any ideas?
            Thanks!
            • crowntoy99
              • Oct 2012
              • 267
              • india
              Any ideas?
              Thanks!
              did you fix this issue
              • crowntoy99
                • Oct 2012
                • 267
                • india
                any idea?
                • cristiannec
                  • Oct 2014
                  • 49
                  • Italia
                  Nope, i did not managed to find any solution.
                  • selekop
                    • Aug 2017
                    • 21
                    • türkiye
                    Originally posted by peste
                    try..
                    thank youu very good
                    • imad.azez
                      • Apr 2018
                      • 8
                      • Syria
                      Request ec bin file fordell inspiron 3476 laptop
                      Hello all
                      I need ec bin file for laptop with motherboard
                      vegas/turis mlk kbl-r 17841-1 wx2rr
                      File size 128 kb
                      io type = MCE1404-NU-GP
                      Thank you
                      • kalya
                        • Jun 2016
                        • 15
                        • od
                        Hello all!
                        Have Inspiron 15 3576 with vegasturis mlk kbl-r 17841-1 wx2rr motherboard.
                        An original dump lost.
                        Laptop still working in Manufacture mode but after press Alt+F battery stand as wrong.
                        Can anyone help?
                        • peste
                          • Dec 2016
                          • 13439
                          • ROMANIA
                          Originally posted by kalya
                          Hello all!
                          Can anyone help?
                          try post#2
                          • fahed
                            • Feb 2016
                            • 7
                            • jordan
                            17841-1
                            Hello, does anyone find a solution to this problem?
                            The battery is original and it works on another device normally
                            Tried more than one battery, same problem
                            A new bios has been programmed
                            And the charging ic has been replaced
                            io . has been replaced
                            The problem has not been resolved!!
                            • U_pasta
                              • May 2020
                              • 12
                              • Brazil
                              i have the same battery problem: Primary Battery Health: Not a Dell Baterry.
                              In manufacturing mode the battery works and charges normally.
                              When I customize for the notebook model the battery error is displayed.
                              I've tested up to the current version 1.16.0 and the fault persists whenever I customize the notebook model.
                              I changed the BIOS binary that made the EC Embedded Controller v1.0.2.bin file available to the EC Embedded Controller v1.0.0 available in BIOS exe v1.3.0 and the failure persists when customizing.
                              • rammstein9910
                                • Feb 2019
                                • 14
                                I had issue with Vostro 3578, powercycle, with flashing Capslock button and flashing Power indicator on the fron of the case of laptop.
                                Made backup of the existing BIOS, erased it, programmed with the BIOS file
                                https://www.badcaps.net/forum/showpo...83&postcount=4
                                Needed to select the model, worked properly, back in life! Thanks guys!
                                • roiinfo
                                  • Jan 2020
                                  • 7
                                  • algeria
                                  Try
                                  hello, you send 256KB bin of EC in this board we have mec1416-NU..Did you try to reprograme this EC?
                                  • JulioChuts
                                    • Nov 2022
                                    • 15
                                    • Brasil
                                    Could someone please clear this bios for me?
                                    Hello badcaps friends, can you clear this BIOS for me? It is not allowing the laptop to turn on, and I have already tested other ones, and the laptop works, but I would like to restore the original BIOS because of the BitLocker on the hard drive.
                                    CASE CODE: INSPIRON 15 3578
                                    MB CODE: VEGAS/TURIS MLK KBL-R 17841-1 WX2RR
                                    MBIOS: G25B128C
                                    CPU:İ5-8GEN (with video card)
                                    SN: DXJVFP2
                                      • 21692
                                      Re: Could someone please clear this bios for me?
                                      MBIOS: G25B128C
                                      SN: DXJVFP2
                                      clear what ? ,if it has a password say it has a password
                                      Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                                      • JulioChuts
                                        • Nov 2022
                                        • 15
                                        • Brasil
                                        Oops sorry, I wanted the machine to not turn on with this bios.
                                          DELL Inspiron 3476 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3476 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3476 boardview and 3476 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3476...
                                          09-06-2024, 08:00 AM
