Asus k550xv shut down after 30 minute
  • pc.heidari
    • Apr 2020
    • 14
    • Iran
    hi . k550vx motherboard x550vx rev 2 , i changed pch sr2c4 and power on .
    but 30 minute working fine and go shut down . i check bios and clean me region with some bios file but shut down after 30 minute . replace other pch but shut down . can you help me ?
    • 22293
    Re: X550VX rev 2.0 need 950m bios dump
    Originally posted by pc.heidari
    hi . x550vx rev 2 i changed pch sr2c4 and power on .
    Which bios did you try.If you have an original bios backup post it here.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: Asus k550xv shut down after 30 minute
      Was the pch part number same??
      • pc.heidari
        • Apr 2020
        • 14
        • Iran
        part ? GLHM170 SR2C4
        • akdenizmusty
          • Aug 2016
          • 46
          • Turkey
          i have same problem but
          my case code : x550vx-dm263tc
          motherboard:x550vx rev:2.0
          chip:sr2c4
          i cleared me side before .but 30m after shut down
          orjinal dump:https://dosya.co/879z4y4k6h0i/x550vxoldd.rar.html
            • 22293
            chip:sr2c4
            What board did you take the replacement PCH from. Post pictures of the white/green stickers on the motherboard,usually they are near the RAM
            • akdenizmusty
              • Aug 2016
              • 46
              • Turkey
              I bought 2 from a site I trust, 1 of them worked without any problems, I puted the other into this device.30m after shut down
                • 22293
                Post pictures of the white/green stickers on the motherboard. They have the info for the bios that the motherboard shipped with.The silkscreened motherboard part number isn`t always the bios version you need.
                Also can you run MEInfo and post the report, you can use the windows or dos version, from post #16 in this thread - https://www.badcaps.net/forum/showthread.php?t=93189 .He is having the same problem as you.As pointed out by piernov in that thread it could be a soldering issue or other problem, i`m just assuming that youve soldered the chip correctly and there are no missing parts,resistors etc.
                • akdenizmusty
                  • Aug 2016
                  • 46
                  • Turkey
                    • 22293
                    Heres a clean bios. Run MEInfo with the verbose switch meinfo -verbose ,if its still the same then try reballing the chip .
                    • akdenizmusty
                      • Aug 2016
                      • 46
                      • Turkey
                      i tried your bios and opens with a delay of 10 seconds
                      +30m after shut down
                      i tried meinfo - verbose
                      • bilen
                        • Aug 2014
                        • 637
                        • istanbul
                        I am experienced the same problem after sr2c4 change
                        did you find a solution? I think this is a bios problem
                        shared file does not work
                        • bilen
                          • Aug 2014
                          • 637
                          • istanbul
                          • peste
                            • Dec 2016
                            • 13924
                            • ROMANIA
                            Clean me region to the original bios.
                            • bilen
                              • Aug 2014
                              • 637
                              • istanbul
                              I tried the result is the same
