Dell Latitude 5410 Bios Password 8FC8
    Re: Dell Latitude 5410 Bios Password 8FC8
    Started up. Thank you Password removed. But the cooler constantly works at maximum speed
      Originally posted by Syavko1 View Post
      OK thank you. Soldered back. But the laptop does not turn on. The cooler works at high speeds, the screen is black
      First boot will be much longer than usual just wait, if you have programmed and soldered the chip as it should everything will be OK, if not do it again.
      Become a Badcaps supporter
      Thanks to all supporters.​
        At first boot press F2, write the service tag, save & restart. After that at the second boot press Alt+F to exit manufacturing mode. And the fan will slow down.
          Originally posted by Vesko356 View Post
          At first boot press F2, write the service tag, save & restart. After that at the second boot press Alt+F to exit manufacturing mode. And the fan will go down.
          Thank you, friend, it worked)))) I am very happy
            You're welcome
            I am very happy
            I bet you are
              Or clean MERegion in this dump
                Originally posted by piotrux
                hi please help me to unlock dell latitude 5410 bios password CXCZX33-8FC8
                Here's your Unlocked Bios, hope it works fine.
                all donations are welcome,
                  Hello, need help
                  i read mi bios chip, and i have a 1mb file...
                  the files posted her is 8 mb size...
                  i need help
                    Originally posted by silocc View Post
                    Hello, need help
                    i need help
                    Hello you must look for the correct chip on the board and read its bin.
                      It works, thanks man.
                        Originally posted by vesko356 View Post
                        you're welcome
                        i bet you are
                        help to unlock dell 5320 plsss
                        attached bios
                          attached bios
                          This topic is for Latitude 5410 not 5320, read forum rules - there's sticky thread for that. Make your request in the 5320 topic!
                            Where find plsss
                              Where find plsss
                              Use "Search this Forum", the search field is at the top right corner of the main page.
                                Hi, please help patch bios to remove password, model is dell 5300, bios 8cf8 128mbit.
                                Thanks in advance.
                                  Thanks in advance.
                                  Wrong thread, sorry. I will repost.
                                    Thanks in advance.
                                    Upload 64Mb aswell.
                                      hi can anyone pls help me unlock this bios for dell latitude 5410
                                      i5 10th
                                        try this and update me
                                          work perfect thank you so much sir
